Old 10-06-2007, 01:04 AM   #1
Freeagnt54
Your Ride: 1998 323is
window repair
i just bought a 1998 323is and both my driver side and passenger windows dont roll up they just make a knocking sound, i went to a mechanic and he said it would be about $400 for each window w/ parts and labor...so my question is does this seem like a reasonable price or should i find someone else to do it thanks
Old 10-11-2007, 12:26 PM   #2
zeit00
zeit00's Avatar
Rate My Car: 38 / 337
You can fix them yourself. I am sure there is a writeup on how to fix the plastic clips that attach to the window regulator..
Old 10-14-2007, 05:22 PM   #3
estpaul
Your Ride: 1996 316i compact
Cool
do it yourself mate, i had the same problem, took me an hour and a half to fix it, the clips that were attached to the motorised arm had popped off due to the window not sitting in the channel properly, when you have taken the panel off, just take the pins out of the clips that are in the arm, regrease the slots an clips, slide the clips into the slots that are attached to the window, make sure the arm position is at the very bottom, then push the arm dowels into the clips and attach the pins, done
Old 10-14-2007, 06:15 PM   #4
xxxbimmer
Rate My Car: 46 / 337
what did he say was broken......... as you hear the knocking sound i am guessing the motors still good...... it is a really easy fix if its just the clips.........
but since he said 400 im thinking your regulators might be damaged....... in that case it is easy again.........
just take your door panel off......and look its fairly simple
Old 10-14-2007, 06:46 PM   #5
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
^^agreed.
it should be an easy fix. If your up to it you can take pics along the way for others with the same issue.
Good luck
Old 10-15-2007, 10:25 PM   #6
Freeagnt54
he never looked at the car he just said they regulators need replacing, but the windows roll down no problem and sometimes the right window will roll up.
so all i have to do is the clips?
Old 03-02-2008, 12:26 AM   #7
xxxbimmer
no sounds like the regulators and or motors are bad..... if the window doesnt roll up and u cant hear the motor turning the odds are u are going to have to replace both...... if your have the money i rec changing them at the same time
Old 03-02-2008, 04:24 AM   #8
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
I did my self before.
Maximum Power
Old 03-06-2008, 11:36 PM   #9
bmdude
Your Ride: BMW350
yeah, you can do it yourself. its really easy to do. I've replaced mine before. Just be sure to install those Edit: We've been over this, everyone here can find BMW parts correctly and properly bolt in. This is to avoid problems in the future. It would also be good to check your window motor and regulator at the same time and see if there's a need for replacement. If you're not sure on how to do it , you may check on the manuals or have someone help you with the job.
Good luck
Old 03-07-2008, 04:32 AM   #10
Rate My Car: 106 / 337
^^^How's that BMW 350 running?
Old 10-05-2008, 11:49 AM   #11
Chaseman
Chaseman's Avatar
Your Ride: 1995 325i 5 speed
I am having an issue with my right side window too on my 1995 325i just hear the motor trying but it is now stuck in the 1/4 up postion. Sounds like I have too remove the door panel and then I can see the window and clips. My question is how do you remove the door panel any special tools needed? any advice would be great. Thanks
Love My Bimmer
Window Motor replacement ???? jonni325 E36 4 08-07-2009 04:27 AM
Is this the infamous window regulator problem? spicytuna E46 3 11-11-2007 12:34 AM
330ci window switch njjeter E46 2 07-21-2007 04:11 PM
Jammed Window RSF5 E46 3 07-17-2007 11:13 AM
rear blind help zx7rhitch E36 12 05-30-2006 02:11 PM
