Old 10-03-2007, 06:07 PM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 285 / 337
Your Ride: 1993 BMW 325is
Lifters on startup
So i've been having issues with ticking and whatnot. but let me confirm this, the e36's lifters DO make noise on startup right, for like 2-3 seconds. cuz if thats a lifter sound my car DEFInetly is not making that noise.
Old 10-05-2007, 08:58 AM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Anyone? I know that mine doesn't...
Old 10-06-2007, 03:26 PM   #3
stevo
Your Ride: 1997 318se Touring
mine don't..........
Old 10-07-2007, 10:34 AM   #4
Mercenary(FH)
i thought that was like......a common thing because it takes a second or two to get the oil to the lifters?
Old 10-07-2007, 11:15 AM   #5
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
you engine gets junked up i believe. Thats what causes that. Also depends on the weather and what viscosity oil u are running. more then likely its cold in the monrnin gand the oil is thick on start up.
my 318 did it when it was cold. then i would just put thinner oil in it and it would be fine. Just keep in mind if it gets too hot and you are running thin oil, then oil can become too thin and itll be like water and wont get to your valves. (atleast in my M42 ie 5-30 in 100 degree weather=no oil to valves. )
Lifters through valve cover? Mercenary(FH) E36 30 09-17-2007 12:13 AM
startup problems?? dh1971 E36 4 07-23-2007 07:25 AM
white smoke on startup swampdonkey E12, E28, E34, E39, E60 5 01-24-2007 07:48 PM
New Valve Lifters (Cam Followers) Kiterunner E36 13 07-02-2006 04:12 AM
idle problem at startup armybimmer05 E36 12 03-26-2006 09:42 PM
