Old 10-02-2007, 09:33 PM   #1
Trini
Trini's Avatar
Your Ride: 1996 328is
codes reset
will disconnecting the battery for sometime reset my system and clear fault codes? cause i do not have a diagnostic/reset tool.
96, 328is
Old 10-02-2007, 10:14 PM   #2
Rate My Car: 84 / 337
I doubt it. But it will cause you to need any radio code you have to use the radio after
Old 10-03-2007, 04:37 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Meh. Some codes. i.e. brake pad sensor wear (if you replaced the sensor) and other crap like that. Engine fault codes? Nope. I tried it.
fault codes '94 318is jeo245 E36 2 08-05-2007 06:57 AM
E34 Service Indicator Light Reset e39 bimmer E12, E28, E34, E39, E60 0 12-31-2006 11:17 PM
resetting inspection bars jybute E12, E28, E34, E39, E60 7 10-15-2005 09:37 AM
Trouble Codes Spieluhr E36 5 05-29-2005 06:29 PM
