Old 09-24-2007, 09:57 PM   #1
dinohm4
Your Ride: 1993 325i
cluster question
hey anyone think that a 1998 328i instrument cluster will fit a 1993 325i? any ideas, my died out and im bidding on one from ebay
DINO:
Old 09-26-2007, 09:28 AM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
It should physically fit. However, the connections could be different. I know that both of the clusters are uncoded, so you won't have a problem in that department, but if the wiring harnesses changed from 1993 to 1998, you'll run into some issues.
Anyone else know about this?
Old 09-26-2007, 09:58 PM   #3
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
if i can remember ill look up the part numbers at work tomorrow and see if they match, if they do then ull be straight
Old 09-27-2007, 10:37 AM   #4
mullethunter3
They don't match exactly. That's why I'm curious as to what changed.
Instrument Cluster. Numark318i E21, E30 4 07-08-2011 11:53 PM
DIY: Replacing Instrument Cluster Lights mullethunter3 BMW OEM Parts Department DIY's & FAQ's 41 01-06-2008 02:16 PM
question for disconnect the battery for replacing the cluster bulbs g328is E36 3 01-19-2007 04:02 AM
Fun With E36 Gauge Cluster Test Functions bitcore BMW OEM Parts Department DIY's & FAQ's 1 05-04-2006 03:08 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
