Old 09-19-2007, 04:02 PM   #1
ecks
Your Ride: 1996 318 is
==> Bypassing Aux Radiator Fan?
Hey guys. I almost have my bimmer's overheating problem taken care of. It seems to help when I have the aux radiator fan blowing at all times. What can I hook it up to so that it runs whenever I turn the car on? Also, is it normal for when the car starts to overheat that coolant bubbles out from under the radiator reservoir cap? I didn't remember that happening before I had these issues. I took the cap out and the o ring in it and everything else seems intact. I just wanted to ask before I spend $25 on the stupid cap. THANK YOU!!!
Old 09-19-2007, 05:37 PM   #2
mzbmw325i
mzbmw325i's Avatar
i think your overheating issue may lie at another problem. have you changed your thermostat lately, fan clutch, did you do a proper flushing if you changed the coolant, i mean proper bleeding (get those bubbles out) when was the last time you replaced your water pump?
i don't hink you want your car overheating often and for a long periods of time, the engine is too fragile for that.
just my 2 cents.
help with A/C and AUX fan eightynine535 E12, E28, E34, E39, E60 14 08-28-2007 09:57 PM
aux fan nij E12, E28, E34, E39, E60 2 04-01-2007 04:54 PM
CD stacker AND aux input possible? Bigsun E12, E28, E34, E39, E60 3 11-26-2005 01:34 AM
