Old 09-07-2007, 10:47 AM   #1
bogeyman
Your Ride: 1992 E36
Technical/Problem - need advice
A couple of (hopefully) minor issues that I would like to deal with pronto...:
1) Ticking noise from engine, is sometimes there and is sometimes not there. I presume this is a noisy camshaft, and subsequently noisy lifters. Do these engines use Hydraulic Lash Adjusters? Can this infrequent problem be resolved by using a thicker oil?
2) Petrol whiff occasionally. Normally smells a little bit after filling up and the few hundred miles after. Beyond half a tank and less, i haven't noticed a smell. Could this be an overflow or tank problem? Should I check any areas in particular just to be cautious?
3) Where is the flipping radio aerial? This isn't really a problem, only I get great reception, and can't see an antennae!
4) Auto box is great, real smooth and shifts spot on. Any preventative maintenance I can carry out to keep it this way? I've been told these units are 'sealed for life', presumably they run on the same oil until death?
5) One query with the shifter, the little 'tell tale' indicator that tells you what gear you are in is stuck in position '1'. How do i release the tell tale from it's prison? :
Thanks in advance people
Tom
Old 09-20-2007, 05:28 PM   #2
StiffCookie
StiffCookie's Avatar
Your Ride: 1992 320i SE
Hi,
Nice to see another '92 E36
1) Ticking noise from the engine is most likely to be rockers/tappets, they tend to get noiser as cars get older. So yeah, I would say your right on that one. - Yes, your car has hydraulic valve adjustment.
Is the ticking just there when you start up? Does it go away after say 15mins or so? If so, this is just the time when the valves distances are being adjusted, if it persists the problem could be the HVA's themselves.
Have you checked you oil level? Too high/low can cause this problem.
If your rockers are damaged, eventually you will get misfiring, very rough idle and black smoke because the valves aren't being reciprocated fully. I am not sure what maintenence is required, so you might want to look it up.
2) Is the smell inside the car or outside?
3) Ah ha lol, this is pretty cool, it's actually integrated into the rear window defogging strips. Neat idea huh. My reception is always perfect too.
4&5) Sorry I don't know anything about autos . But I'm sure you can get oil for automatic gearboxes, if so, be sure to keep that topped up (but I don't think you should lose oil unless theres a leak).
Hope that helps ya out
Stiff
Old 01-15-2008, 07:57 AM   #3
bogeyman
Your Ride: 1992 E36
Hi Stiff
Thanks for your reply!
Sorry I didn't reply sooner, haven't been here for a while!
1) Ticking happens every so often, on a hot or cold engine, and also at certain revs. Sometimes when 'cruising' the ticking is noisy, and when i 'press on' or accelerate, the ticks go and all is hushed again. I've seen cam kits, although they cost more than the car did, so i'm really after keeping it in as good condition as poss for as long as poss.
I've been keeping tabs on oil, but in nearly 8000 miles it hasn't used a drop. It's getting serviced every 6k miles.
2) Smell is inside. Smell has gone recently, which is strange. I'll keep tabs on it.
3) Awesome to know, thanks!
4&5) Cheers for info, i know a little more about the autobox now. As it is sealed for life, the level can't be checked unless you open the thing up, and in which case you may aswell renew the seals, filter and oil. At the MOT (yearly test), the tester told me the 'box was leaking. Also he said the rear axle is leaking. I think these two jobs will be done as and when, by a mechanic with a set of proper ramps!
Old 01-15-2008, 01:14 PM   #4
bogeyman
Your Ride: 1992 E36
Looking over the service history of this car, ive also noted that the cambelt needs changing...can anyone confirm whether this engine (1.6 injection) uses a belt or a chain? I'll have to open the engine up if i can't get an answer here.
Old 01-16-2008, 05:14 AM   #5
max79
max79's Avatar
Rate My Car: 194 / 337
Your Ride: E38 1998 740i
if ur car is 316i it comes with m40 engine with cambuilt built not chain
740i
Old 01-16-2008, 05:16 AM   #6
bogeyman
Your Ride: 1992 E36
Thanks for the reply!
I'll have to get it changed then
Old 01-16-2008, 08:43 AM   #7
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
As for #3, it's not in the defrost strips in the rear window. It's behind the C-pillar. I can't remember if it's passenger or driver's side. It's just a box behind the upholstery.
Old 01-16-2008, 12:10 PM   #8
StiffCookie
1) I would try just replacing your lifters, a good percentage of E36's have this prob and worn/faulty lifters are the cause. If this doesn't fix it, It will most likely be the tensioner.
2) Probably not the case, but lift up the rear seats and check under the metal plates either side of the car (by removing 4 screws each side) to see if you have any fuel seeping through the seals where the fuel level senders are. Make sure the BIG plastic nuts are securely tightened.
Ah, the US and Euro versions of the E36 must be different then, because mine definately has the defrost strips double as the radio antenna (100% Certain).
So depending where ur car was registered bogeyman, now u know
Hope this Helps
Stiff
Old 01-16-2008, 12:16 PM   #9
iamcreepingdeath
iamcreepingdeath's Avatar
Make absolutely sure you are using the correct oil. Look in your owner's manual. It happened to me. get this. I had up until yesterday been using 10w-30 in my '95 E36, and i always had a ticking kind of rattle coming from the front of my engine. I looked in the owner's manual, and lo and behold, my car needs 15w-50, a much heavier oil. So i did the change last night, and the ticking was gone, just like that. My car runs much smoother now. look in your owner's manual, i cannot stress that enough.
Bmw Advice mlongo2005 7 Series (E23, E32, E38, E65, E66) 9 11-14-2010 12:03 PM
DIY is progress... need quick advice mullethunter3 United Off Topic  **FOR MEMBERS ONLY** 2 01-06-2007 07:46 PM
Need advice - want to buy 98 528i patrickjoseph E12, E28, E34, E39, E60 2 05-30-2006 05:29 AM
Looking at 528's . . advice? Dudesky E12, E28, E34, E39, E60 8 04-05-2006 08:43 AM
Need advice on mods Rooz E36 30 08-18-2005 03:00 PM
