Old 08-17-2007, 10:52 AM   #1
falcon900
Your Ride: 1997 328i
how do I read ABS fault codes
My ASC and ABS lights will come on intermittantly. When they are out ABS and ASC to work I tried them. I suspect I'm loosing a wheel sensor. How do I retrieve fault codes, I dont think I can get the from the engine code reader. Any help on this.
Old 08-17-2007, 11:11 AM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
I thought the engine code reader read that as a code also?
Old 08-17-2007, 11:15 AM   #3
Rate My Car: 106 / 337
No it doesn't. Those fault codes are stored in the ABS control module. Unfortunately they can only be retrieved by an authorized service center
Old 08-18-2007, 07:26 AM   #4
elektron85
Your Ride: Bmw e36 318i m43
Old 08-18-2007, 04:04 PM   #5
Rate My Car: 183 / 337
Originally Posted by elektron85
you sir are a bloody idiot.
and for the ABS thing, my car does that sometiems(actually, very very rarely, only twice since i bought it) but i just turn the car off and back on and its gone
Old 08-23-2007, 04:22 PM   #6
falcon900
Here's what I found and found it. I disconnected the elec. plug on the ABS and ASC box and ran a resistance check to each monopole
(wheel speed sensor). I compared the resistances 3 measured 1.111K the forth measured 30,000m. So with that I going for the left front monopole. The computer sees this and goes to fail safe ABS and ASC light comes on, back to conventional braking.
I'll let you know how it turns out.
Old 08-24-2007, 02:20 PM   #7
falcon900
Fixed it, it was a front wheel sensor. They are a real treat to remove.
The job is done and both ABS and ASC lights went out after a short drive.
Old 09-10-2007, 09:21 AM   #8
3050rpm
3050rpm's Avatar
Could someone tell me where the wheel speed sensor is located? Both the ASC and ABS lights have been on constantly whenever I drive the car, for the past four days or so, which is something new, have never had this happen before. I haven't done any recent brake or wheel work, the brake fluid is only a year old, and the only thing I did was wash the wheels prior to this happening, so maybe somehow kinda the sensor got wet, although why this hadn't occurred before in the rain is an oddity...
Old 09-11-2007, 10:27 AM   #9
falcon900
The wheel speed sensor is located at the hub of each wheel, by the brake assembly. Check the wires to make sure they are'nt damaged. If they appear ok then I'd check all 4 with a meter at the computer.
Old 09-11-2007, 11:52 AM   #10
3050rpm
3050rpm's Avatar
Thanks for that. I suspect it's just a loose connection, or something in need of some cleaning. Of course, it's raining now, so checking it out will have to wait...
fault codes '94 318is jeo245 E36 2 08-05-2007 06:57 AM
OBD I fault codes trick kjprince E36 0 03-06-2006 03:09 PM
Car Done! ABS code read, Brakes/Rotors checked out for $25! delmarco E36 9 07-11-2005 04:24 PM
Fault codes - got a bavauto diagnostic tool billycuth E36 4 05-06-2005 01:18 AM
