Old 08-15-2007, 06:02 AM   #1
chandra
Your Ride: 1992 318i
1992 318i plug wires
I pulled my spark plug wires and lost track of which order they hook up to the coil packs. Can somebody help me?
Old 08-15-2007, 07:54 AM   #2
Rate My Car: 183 / 337
a picture of someone else's 318 probably would be your best bet, or if you could find a wiring diagram it will tell you which one to connect to which
Old 08-15-2007, 08:44 AM   #3
Rate My Car: 106 / 337
Dunno if this helps, but the firing order is 1-3-4-2.
Old 08-15-2007, 11:47 AM   #4
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Okay, I lost the cord to my camera in the move back to college, so a verbal explanation will have to do. Sorry.
From the front of the car, I'll call the first cylinder #1 with the last being #4. The longest wire goes into #4. It kinks backwards before going in the hole. The shortest wire goes in #3. The next, slightly longer one goes in #2. And finally the next, slightly longer one than #2 goes in #1. Wires 1-3 should lay straight while the wire for #4 will turn back before going in its place.
Hope that helps!
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
E30 Stock Headunit/Stereo to Aftermarket celsdogg Car Audio and Electronics 7 09-25-2007 03:35 PM
Oil covering spark plug - help! larryglover@gulfviewllc.c E36 3 05-07-2007 09:53 PM
weird CEL... ivopivo E36 46 03-22-2006 01:22 PM
do i need special plug wires ? j123crx E21, E30 2 11-20-2005 09:57 PM
