Old 08-07-2007, 05:13 PM   #1
falcon900
Your Ride: 1997 328i
troubleshooting ASC and ABS light
My ASC and ABS light came on today and did'nt reset at startup. Anybody have any troubleshooting tips .
1997 328i
Old 08-07-2007, 05:43 PM   #2
Rate My Car: 84 / 340
Possible need for a brake fluid change?
Old 08-07-2007, 06:49 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
We are going to need more information than that...
Did you recently replace brake pads? Did this happen randomly?
Sometimes, you can clear the fault warnings by disconnecting you battery. Just remember that you'll need a code for your radio if you still have the stocker.
Old 08-07-2007, 08:19 PM   #4
Rate My Car: 106 / 340
Some warning lights and fault codes require a few start cycles before they go out. I don't know if this is the case, but I'd wait to see before you freak out.
Old 08-07-2007, 10:25 PM   #5
falcon900
No maintenance performed on the brakes prior. This occurred out of the blue. The wheel speed sensor wiring appears intact. I checked all the fuses associated and removed and reinstalled the ASC relay and the ABS relay.
Old 08-07-2007, 11:02 PM   #6
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 295 / 340
Your Ride: 99m3
wheel sensor may be bad, when both are on(asc & abs) that is usually the culprit.
Old 08-08-2007, 08:29 PM   #7
falcon900
The lights just went out, it maybe a wheel sensor. I did clean the electrical contacts. I removed the screw holding the sensor, but could not remove the sensor. I'm assuming it's corroded around the sensor boss. Any tips on removal?
e36 ABS & ASC stays on after front strut installation! johnnybayonne E36 4 07-12-2007 02:25 PM
