Old 08-07-2007, 02:05 PM   #1
bbimw
Your Ride: 99 323ic
e36 abs idiot light
have the last 99 e36 323ic, my abs light goes on, after the second start of the day and does not go off, until the following day, when restarted. The code that comes up after the light is on, is that the abs pump is faulty. i am wondering if this could be relay related, or any brainstormers out there that might know what the cause would be.
Old 08-07-2007, 02:23 PM   #2
Rate My Car: 84 / 340
Could be you need new brake fluid
Old 08-07-2007, 06:51 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
Try and reset the codes. This can be done on some, if not most, E36's by disconnecting the battery for a while.
Do you have a Bentley Manual?
Old 08-07-2007, 08:16 PM   #4
Rate My Car: 106 / 340
Many ABS pump relays prior to 05/96 were defective, but that doesn't apply to you. Still, it may be that your relays are going bad prematurely. That would be where you should start, and hopefully that's it. If not, you may have to get it looked at by an authorized service center. The Bentley doesn't cover ABS repairs
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
e36 ABS & ASC stays on after front strut installation! johnnybayonne E36 4 07-12-2007 02:25 PM
ABS Light from HELL!!! So it's on again after the dealer fixed it! delmarco E36 7 08-06-2005 10:04 AM
Back to the dealership! yearly inspection, ABS light, new pads&rotors$$$$ delmarco E36 14 07-07-2005 09:42 AM
ABS check light came on!!! please HELP!!!! delmarco E36 9 07-06-2005 08:27 PM
