Old 07-27-2007, 12:17 PM   #1
Cougar1818
Cougar1818's Avatar
Your Ride: 98 323IS
Radio light
New to the board, does anyone know how to replace the bulb in the radio display on a 98 e36 car?
Any help appreciated.
Thanks,
Old 07-27-2007, 03:09 PM   #2
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
What model radio ?
Old 07-27-2007, 03:41 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
On a 1998 323i, is the radio display LCD or back lit by a bulb? I could have sworn that it was LCD...
Old 07-30-2007, 03:06 PM   #4
stlbrouha
Your Ride: 1998 323is
yeah, it's lcd- and prone to dimming. good news, though- with the sunroof open, and direct light to the unit it's readable with your head tilted slightly to the right.
and if anyone knows the real answer.... i'd love to be able to see mine too.
Old 07-30-2007, 05:59 PM   #5
Cougar1818
Cougar1818's Avatar
Your Ride: 98 323IS
radio light
I believe it is the same as the computer, which has small bulbs which I have changed. I can barely make out the numbers and once in a while it comes back on which leads me to believe it is either dying or loose connection driving me nuts. Help anyone?
Old 07-30-2007, 06:01 PM   #6
Cougar1818
Cougar1818's Avatar
Your Ride: 98 323IS
Originally Posted by testm3
What model radio ?
Stock radio 1998 323IS
Old 07-30-2007, 06:53 PM   #7
3050rpm
3050rpm's Avatar
This might get you started on how to get it out http://www.pelicanparts.com/BMW/tech.../E36-Radio.htm , a little fiddling around and you might be able to find out how to get at the bulbs, available at the dealer or Radio Shack.
Old 07-30-2007, 10:12 PM   #8
Linds
Linds's Avatar
Rate My Car: 68 / 337
Your Ride: 97 M3
I had this problem before, and tried to fix it with the write-up below (from bimmerforums.com). Unfortunately, I broke something else on it so I ended up getting a new head unit anyway, lol. Hope this helps!
There are actually a couple things possibly wrong. The bulbs under your LCD might be burnt out, kinda unlikey, or they might not be getting power at all.
What you'll need:
A soldering iron, preferably with a fine tip.
Thin solder
A smallish philips head screw driver
A flat blade screw driver
Needle nose pliers
A multimeter
The security code for your radio
I took pictures, yes. But unfortunatly I didn't take one of what you really need todo and I don't feel like disassembling my headunit again.However, its not really needed, as it is totally possible to descibe how to do it.
First of all you need to pull your radio from the car. There are little hinged tabs on each side of the radio. Pop them open. The screw in here has 5 sides, but you can make a hex wrench work fine. Unscrew as far they'll go and jimmy the headunit out. For those with an M3 you can substitute a hard 1-2 shift at the redline for the jimmying, the radio will slide right out. Ask me how i know. Disconnect the big black connector by following the disgram on the top of it. You'll have use some force with the screw driver when prying it up, it will make a real ugly sound when it pops off, but everything is fine.
Bring it inside and take the plastic cover off. There are 2 screws, one on each side, near the top, towards the front of the unit. Then there are tabs near the bottom that need to be pushed in as well as one on the top that also needs to be pushed. Everything else is kind of a prying exercise
Now we need to take the top cover off of the unit. Two screws in the back, toward the top need to come out. Then it just pulls off.
Next stop is pulling the display circuit board out. There are 2 screws attaching it to the tape player assembly. Then there are 2 metal tabs on the side of the unit that need to be pushed in. Make sure you disconnect the little socketed wires for the volume knob on the left side of the unit. There's a black piece of wire holding it in place that serves no other purpose and is safe to bend. Now you should be able to pull the displayboard clean out. Set it aside.
The tape player now needs to be removed, there is one screw on the left side near that beige plastic thing and one on the right side down a square hole. Then just pull the entire assembly up, set aside.
You have now arrived at the main board, the source of all your problems. Time to head back your car with the unit, the front display circuit board and your multimeter. Plug that wired volume button back into the main board, and plug the unit back into the car. Put your keys in and turn on the electrics in the car. Now push the volume button in to turn on the stereo. You need to figure out if those bulbs under the display are even getting any power,Toward the front of the unit you will see 2 red connectors. Looking at unithead on, the socket on the left and the last pin hole all the way to the left is the one that powers the bulbs under the LCD. You should get just under 12v on your multimeter from it. I pull up the ciggarette lighter connector and use the ground under it for my ground.
IF YOU DON'T GET POWER FROM THAT PIN (scroll down for instructions if you do)
Head back inside with your radio. Disconnect the volume dial again. Take a look between those 2 red connectors again. In between them you will find a couple surface mount resistors. They are litte black rectanges with the number "180" on them. These have cracks in the solder on each side of them too small for the human eye to see. What you'll need todo is just touch up these joints (4 joints total) with alittle solder.
Now repeat the above paragraph and make sure you're getting 12V now. Turn off the radio, reattach the display board, including plugging the pins back into those red connectors. Turn radio back on. Does your display light up nice and bright now? Good! You're done! ......if it doesn't proceed to the next section.
IF YOU DO GET POWER FROM THAT PIN
This means those bulbs under the display are likely burnt out.
Extra stuff you'll need:
Copper desoldering braid
2 8v microlamps available at partsexpress.com
You'll need to remove the metal backing from the display circuit board. There are 2 metal tabs holding it by way of holes in the circuit board, desolder these tabs from the board and bend the tabs back. The display board should come off fine now.
Now removed the actual LCD display, again, more tabs to desolder, 3 along the top of the LCD, one of which is through the circuit board. Then 3 more along the bottom, but these may not be soldered, you probably just have to bend them back, Removed the display and you'll see the bulbs. Desolder them and resolder in the new ones. Go out to your car and make sure they work. If they don't, I don't know what to tell you, this all worked for me, Very sorry.
If it did work, congrats, reassemble your radio and enjoy!
Hope this helps a few people!
Old 07-30-2007, 10:18 PM   #9
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
great write-up! If the 6 disc cd changer ever worked when I bought my car I would probably still have the stock radio.
Old 07-30-2007, 11:36 PM   #10
Linds
Linds's Avatar
Your Ride: 97 M3
Yeah I actually wish mine still worked. The aftermarket one I bought has terrible radio reception. Thankfully there's an aux input for my mp3 player.
Old 07-31-2007, 11:02 AM   #11
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah thats the issue with most aftermarket headunits, radio quality on an OEM radio is much better. Mine doesnt have an aux input so I use the tape with the cable that goes into the headphone port on the ipod in my golf. I need to find something for my 325..
Radio & Warning Light Problem larsonc E21, E30 6 11-20-2006 08:35 PM
HD Radio, yay or nay + goodies doughboyea Car Audio and Electronics 2 09-25-2006 09:16 PM
C33 radio and Changer bakaroo United Off Topic  **FOR MEMBERS ONLY** 0 08-29-2006 02:42 PM
How many forum members does it take to change a lightbulb? bmwcrazy Comedy Collection
6 11-20-2005 08:31 PM
XM Radio Announces 5 Million Subscribers komodo Car Audio and Electronics 12 10-07-2005 12:36 AM
