Old 07-23-2007, 05:37 PM   #1
ebadeau
Your Ride: 93 325iS
Electrical
Basic Points:
Battery Fully Charge.
No Rain by ECU
Starter Replaced
Basics Work
Fuel Pump works and was replaced 3 month ago.
Fuel goes entirely through fuel rail
New Spark Plugs
Can't test Alternator unless car is already started...
Fuses are good
1/2 Tank of Gas
Problem: Car Doesn't Start?
The are 'cranks' but doesn't turn over.
Solution: Before I start replacing parts like a crankshaft sensor. What might also be a problem with it?
v/r
Ed
Old 07-23-2007, 07:00 PM   #2
Cellardoor
Your Ride: 95 M3
so u get the "chugging" type noise where the pistons are moving but u cant get the car to give u any internal combustion?
1) are u sure the sparks are sparking to ignite the fuel?
2) could be the crankshaft sensor
3)im not sure, thats the first thing that comes to mind, because if it was the starter it wouldnt crank at all. If it was the batt it wouldnt do it either.
good luck man.
O! is the car throwing any codes? if so have that checked out it could help ALOT!
-Hutch-
///M Accelerate till you see GOD....then Brake
If life passes you by...............Downshift
Old 07-23-2007, 07:54 PM   #3
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
first thing to do is check codes
Old 07-25-2007, 06:19 PM   #4
ebadeau
Your Ride: 93 325iS
How do I test to spark plugs to ensure its sparking? I replaced the plugs/coils.
Could it still be the crankshaft sensor even its still a "chugging" noise?
Whats the pedal trick to get the codes?
Thanks
- Ed
Old 07-25-2007, 07:26 PM   #5
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
I would bet its the crank sensor.
electrical jybute E36 6 05-10-2010 02:14 PM
635 csi - electrical fuel trouble bagheera 6-Series (E3, E24, E63, E64) 3 02-10-2010 08:17 AM
Just finished clutch repair, now electrical system won't charge? bearcat77070 E36 4 02-26-2007 06:24 PM
Electrical Maintenance "101" c1apton BMW OEM Parts Department DIY's & FAQ's 5 11-30-2006 07:48 PM
Electrical Rumor dnhynz Z Series (Z3, Z4, Z8) 3 08-03-2006 03:22 PM
