Old 07-16-2007, 02:54 PM   #1
justplainmitch
Your Ride: 1993 BMW 325is
Sagging Head Liner!
Alright, I am getting sick of my saging head liner, so I think it is time I replace it. Is ther a specific Glue and Fabric I should Use? HOw long should a project like this take? Thanks for the help.
Old 07-16-2007, 03:25 PM   #2
intelbank
Your Ride: 1992 325i
There's actually a thread here somewhere that outlines the entire Sagging Headliner procedure, including where to get the material at.
I actually found the thread: http://www.unitedbimmer.com/forums/t...dliner+removal
Provided that your underlying board is still in good condition, you should get away with just placing new fabric on it. If the fabric is still good enough, i used 3M spray glue on it. My mistake was that i tried to glue it back in place when it was too cold outside - result: the headliner came loose again. Room temp is recommended.
Good luck!
IB
Old 07-17-2007, 08:09 PM   #3
ts03m3
Your Ride: '03 M3
You can also check with your local upholstery shop. What I do is remove the headliner and drop it off, they recover it and I pick it back up, then re-install it. The bulk of their labor is getting the liner out and back in.
Since this is a common problem on all cars most shops have material on hand you can choose from, so just pick one about the same color.
Old 07-17-2007, 11:01 PM   #4
Linds
Linds's Avatar
Rate My Car: 68 / 337
Your Ride: 97 M3
Yeah I'd suggest an upholstery shop also. Doing it yourself is a pain in the ass. A word of advice if you do DIY though, make sure your material isn't too thin, as the adhesive you use could soak right through.
New Head Unit RSF5 Car Audio and Electronics 10 03-09-2006 11:48 PM
m42 head w/m44 block e30boarder E21, E30 33 08-09-2005 04:19 PM
E30 325i M20 head gasket witeshark E21, E30 5 06-19-2005 12:57 AM
