Old 07-16-2007, 08:32 AM   #1
dinohm4
Your Ride: 1993 325i
Fuel Pump
My Car Try To Start But Its Like Its Not Getting Enough Fuel To Turn On. I Will Replace Fuel Pump Any One Have A Diy On Replacing Fuel Pump For 93 E36
DINO:
Old 07-16-2007, 02:49 PM   #2
justplainmitch
Your Ride: 1993 BMW 325is
Use the link below! I did the fuel pump in my 93 325 about 3 weeks ago! Very easy to do. took about 15-20 min using the diy below. Good Luck. DO you know how to check if its bad? I took a multi meter and took voltage readings at the pump. So I knew I had good power. One of the plugs should have 12v all the time if the key is on. Can't remember which wone it was though. The other would be zeroed untill cranked over and then It went to 12v
http://www.unitedbimmer.com/forums/t...placement.html
Help With Fuel pump and no power!!! POS_BMW E36 7 11-27-2009 10:14 PM
Fuel pump zeaq328i E36 12 04-28-2007 12:08 AM
fuel pump vIcKtOr9 E36 3 03-05-2007 01:12 AM
