Old 07-13-2007, 06:05 PM   #1
Sleepy81
Your Ride: 316i
316i rough idle when cold
I have a 98' 316i Touring.
After an oil change my car started to idle rough when it's cold. Varies between 500-1100 rpm, and the engine shakes so bad that I can feel it in the coupe and shifter. Also sounds very strange/rough.
However, all these symptomes go away within 30-60 sec, and after that everything is completly normal. Stabilizes at around 900RPM.
Any thoughts?
Could it have anything to do with the oil change (used syntetic castrol 5w-40 oil, 4 liters, as per instruction book with filter change), or is it just a coincidense?
Thought about a dirty/sticky ICV, but does these symptomes match that? I would think that the symptomes would last longer than 30-60 sec with a sticky/dirty ICV?
Old 07-14-2007, 07:38 PM   #2
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
ICV is most likely the culprit. my car used to do the same kind of shit. while i was doing the M50 intake manifold swap i took mine out and cleaned the hell out of it and that RPM fluctuation and roughness completely went away. its very simple and i believe theres a DIY writeup for it here on UB, just search for it and if its not on here its on the internet believe me. p.s. - after u do that try running some seafoam through, itll clean out a ton of the carbon buildup and shit in your engine and itll run much smoother. (hint: it says on the can once u pour it in to leave it sit for 5 minutes or whatever. let it sit for hours, the longer the better, trust me on this one
Old 07-15-2007, 05:30 AM   #3
Rate My Car: 137 / 337
+1 to "215s" thoughts, plus after using SeaFoam change your fuel filter. Seafoam is some powerful cleaner as with any good fuel additive, first HEALTHY dose should closely be followed by a fuel filter change.
Old 07-15-2007, 08:51 AM   #4
Sleepy81
Your Ride: 316i
Ok, I'll try to clean the ICV and see if that helps.
But what I don't understand is why it runs like normal after only 30-60 sec. Can anybody explain that to me?
Old 07-16-2007, 02:51 PM   #5
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
oh, please upload some pics of your touring
Deus ex machina
E30 325i Touring
Idle vibrations E39 540i lacikam E12, E28, E34, E39, E60 15 10-24-2011 11:47 PM
Rough as hell idle. WTF mate? mullethunter3 E36 6 06-29-2007 01:08 PM
Cold idle vs Running idle Jami318is E21, E30 3 06-27-2007 01:56 PM
93 318is engine rough idle LILSCARFACE E36 2 11-01-2006 10:31 PM
Rough Idle + CEL Rooz E36 5 03-22-2006 09:30 PM
