Old 07-13-2007, 03:28 PM   #1
cavalry13
Your Ride: 1993 325is
Faint Fuel Smell
Hi all, this is my first post on the forums but I must say from what I've read your all very knowledgeable. Now on to my issue, as of late I get a faint smell of fuel while outside the vehicle, it’s not all the time, but its still there. I’ve looked underneath the vehicle and have seen no signs of a leak. Any ideas or suggestions? I should also note that the car is running normally, there is no performance issues or problems starting. Oh, and this is on a 1993 BMW 325is, I'll post pictures of it as soon as I can.
Thanks,
Scott
Old 07-13-2007, 03:45 PM   #2
Rate My Car: 84 / 337
Does this happen after topping off a fuel fill up? If so it's likely the fuel expanded some and the overflow relief let a bit out.
Old 07-13-2007, 04:49 PM   #3
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
When I drive hard after a fill up I often get leaking from the gas cap area, don't smoke near it and you should be okay.
Old 07-13-2007, 04:59 PM   #4
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
I have had that gas smell for the last couple weeks on my E30, too...
mixed with another weird smell (I bolted on a new exhaust a couple months ago and painted it, so for a while it should stink b/c of the paint burning in, but it keeps smelling like burnt paint even now, 2 1/2 months later.)
Deus ex machina
E30 325i Touring
Old 07-13-2007, 05:10 PM   #5
3050rpm
3050rpm's Avatar
I think it'd be worthwhile to get the car up on a lift and then trace the fuel lines back as best as you can, noting particularly the connection with the fuel tank, where corrosion can set in. You might have a barely perceptible leak that evaporates before it hits the ground, but leaves a scent nonetheless. Similarly, see what you can see of the filler neck from underneath, if it has a crack or tear. If you start smelling something inside, then it might be the gasket around the fuel pump, located under the rear seat. One other thought, the fuel filter...
Old 07-14-2007, 12:30 PM   #6
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Look underneath the vehicle when the car is running. That would be the only time you would see a liquid fuel leak. Trust me, I know. My car hasn't been running for three weeks because of fuel issues.
Help With Fuel pump and no power!!! POS_BMW E36 7 11-27-2009 10:14 PM
Fuel pump zeaq328i E36 12 04-28-2007 12:08 AM
A bit worried, there's a very faint oil smell... chazno5 E36 12 05-23-2006 01:17 PM
