Old 07-07-2007, 11:17 AM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 285 / 337
Your Ride: 1993 BMW 325is
Engine ticking sorta found, help me!
Ok So I Finally took a little time to narrow down this engine ticking (under acceleration) i found, and my VANOS noise
i used my dads stethescope, and went to work
after taking off the valve cover I revved it and listened around
ok now pardon my MS paint 1337 skills but I drew a psuedo diagram, perhaps yall can tell me what it is(btw took a google pic, but same engine etc.)
Ok it's attached but it's VERY VERY Small im sorry, but ccant upload any large pics
but let me explain the colors
the vibrating/knocking sorta noise(when revved, and sometimes after driving hard when idle) is the Green Arrows (vanos I suspect)
the blue area is where the ticking seems to be coming from when I rev it, I dunno what that area is? but it wasnt near the YELLOW area, which under stethescope sounded fine, obviously a little loud, but hey it's an engine, im guessing the yellow area is where all ur cams and important stuff is right?
I pretty much can guess the green arrows are vanos? vanos noise seems to be pretty common, the blue area ticking tho.....i just have no clue?
remember tho, my car drives fine? it's just annoying
plz help me tho!
thx, and sorry for small pic!
Old 07-08-2007, 08:19 AM   #2
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
my car used to make a slight ticking noise, but then I changed the viscocity of oil and the noise went away. If it sounded almost like marbles then your vanos would probably need replacing, or at least the solenoid.
Old 07-08-2007, 09:09 AM   #3
Mercenary(FH)
Yeah I do use like Durablend, is the solenoid expensive? or hard to replace, and yeah it does kinda sound like marbles under acceleration
is the ticking/marble noise under acceleartion like damaging to my engine? or just more of an annoyance
Old 07-08-2007, 09:14 AM   #4
Mercenary(FH)
http://www.youtube.com/watch?v=1WHgZS5KrzI
right there, when the car decelerates thats exactly what my VANOS sounds like, of course my car sounds a TON better, but when the car is like unrevving? it makes the almost exact same knocking noise, im guessing thats my vanos
http://www.youtube.com/watch?v=krNxZwxDmz8
this i guess is a lifter noise when they say ticking? because that is DEFINETLY NOT what my car sounds like, so im guessing it's not the lifters, mine is definetly more of a marble sound?
but it's coming from that blue area? so i dunno whats on the blue area?
Old 07-08-2007, 06:07 PM   #5
Mercenary(FH)
btw is the blue area anywhere near the lifters? or are the lifters in the yellow area, so if they were making noises i would hear them in the yellow area?
Old 07-08-2007, 07:27 PM   #6
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
hmm that seems strange then
Old 07-08-2007, 07:51 PM   #7
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
honestly just take your valve cover off and take a look inside....its EASY and that way you dont have to guess where all the parts are...if you take it apart you will understand everything much more clearly
Old 07-08-2007, 10:34 PM   #8
Mercenary(FH)
when u put the valve cover back on, do u need that "goo" shit that seals ur valve cover gasket?
and the blue area i pointed out tho, thats not where the lifters are right, their in the yellow area am i correct?
Old 07-09-2007, 02:20 AM   #9
B_w.
you just need some silicone sealant ($10) to seal the gasket at the back behind the cams...the lifters are underneath the cams
Old 07-09-2007, 08:36 AM   #10
Mercenary(FH)
Ah ok, i might have to do that, but ticking on the right side of the engine(passenger) is still kinda weird
but can someone plz answer me this, the LIFTERS (that are known to make noise) are on the driver side of the engine (aka the yellow part i drew on the picture up top)
correct
Old 07-09-2007, 02:39 PM   #11
B_w.
you have lifters underneath each lobe of each cam
Old 07-09-2007, 02:43 PM   #12
Mercenary(FH)
and the cams would be on the left side? im assuming, i called the mechainic he said the lifters would be in the middle?
Old 07-09-2007, 03:32 PM   #13
B_w.
you have an intake cam on the driver side of the cylinder head and an exhaust cam on the passenger side...
the cam pushes on the lifter which acts on the valve spring to open and close the valves...
Old 07-09-2007, 03:41 PM   #14
Mercenary(FH)
hmm since it's in the middle of my enigine I guess that makes it hard to diagnose
the exhaust lifter being bad would prolly be less serious Im assuming
Old 07-09-2007, 07:49 PM   #15
B_w.
noisy lifters are not necessarily a bad thing...
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
Search Engine Optimization and Tweaking komodo United Off Topic  **FOR MEMBERS ONLY** 23 04-07-2006 11:12 AM
dream e34 M5 dinan540 M5 5 01-19-2006 12:17 PM
