Old 07-10-2007, 08:47 AM   #16
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 284 / 340
Your Ride: 1993 BMW 325is
yea the guy made it seem like I was gonna ruin my camshaft...
Old 07-16-2007, 11:33 PM   #17
jdgoff
Location: SW corner of CO, live in country near village called Mancos
Your Ride: 1992 325i & 2004 325xi
The early m50 engine, at least on the pre-vanos version, is noted for noisy lifters. In fact in some instances (reference: Roundel magazine tech editor) BMW had to replace lifters. My '92 has noisy lifters, and I thought to replace them until I found out what a bitch it is. There is a special jig required to keep constant pressure on cams. See Pelican parts for more info on lifters. On the other hand, if what you hear is not lifters but detonation (pinging), then you might take a look a the ping sensor that is supposed to alter ingnition timing to eliminate ping. Uncorrected, detonation can be harmful to engine. If sensor is the problem, it should be inexpensive and easy to remedy.
James in Colorado
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
Search Engine Optimization and Tweaking komodo United Off Topic  **FOR MEMBERS ONLY** 23 04-07-2006 11:12 AM
dream e34 M5 dinan540 M5 5 01-19-2006 12:17 PM
