Old 07-06-2007, 11:51 AM   #1
Butterfly
Your Ride: 1995 325I
code
I installed my intake yesterday. After that my radio would not work and was asking me for a code. I dont know this code and the previous owner said it was what was in the manual. I tried 1234 but the alarm went off and the engine locked. I reset the battery so i got the engine to work but still no radio . Any suggestions?
Old 07-06-2007, 12:20 PM   #2
Rate My Car: 84 / 337
You may need to contact a dealer or BMW.
Old 07-06-2007, 12:34 PM   #3
3050rpm
3050rpm's Avatar
The radio code would have been included with the packet of booklets including the owner's manual, service record, etc. The 5-digit code would have been on two credit card-like enclosures; the code is entered whenever the power is disrupted to the car. If it can't be found, I believe the dealer can retrieve it, but I heard one ungodly story that the dealers have to submit the request to Germany. I'm not sure if that holds true nowadays.
Old 07-06-2007, 12:36 PM   #4
Rate My Car: 137 / 337
your code is a 5 digit # - it should be with your owners manuals (usually a grey sticker) if not,you need to go to a BMW dealer, they will pull the radio, get the serial # off it and then run that # for your code. If you do have the code enter it until you hear the beep- * if you hear the beep anywhere along entering the code RESTART entering at that point.
*TIP - once you get the code write it down in your trunk lid toolbox under one of the wrenches.
Old 07-06-2007, 02:16 PM   #5
Butterfly
I found a sheet with the radio serial number and radio code. I tried this code a few times but it dint work. You press the numbers on the radio right? its different then the code that shuts down the engine?
Old 07-06-2007, 02:18 PM   #6
AFAIK the radio code is put in by the radio station preset buttons
Old 07-06-2007, 02:38 PM   #7
Butterfly
hmm well i hear the beep, then i enter the radio code that i found in the car but it just beeps again, so i guess its different or changed, don't know why.
Old 07-06-2007, 03:44 PM   #8
let it sit for 24 hrs. It only lets you try 3 times within 24hrs
Radio Code mrkbik E36 16 03-13-2011 09:48 PM
Peak Code which I dont understand. Help! kvadgama E36 1 06-08-2007 12:36 PM
Paint Code dinan540 E12, E28, E34, E39, E60 6 04-10-2007 04:07 PM
bimmer blues...code 1286 sgreyzee E36 6 10-18-2005 06:47 PM
Ran my code reader this morning before my appointment - 3 new codes billycuth E36 8 06-28-2005 07:41 PM
