Your Ride: 1993 BMW 325is
trans warning light
I need to figure out is the tranny warning light. (Auto Trans) I comes on time to time. puts the car into limp mode. If I kill the juice it will usually reset. Is tis connected to any of the relays? Im thinking that when the fuel pump went it also screwed up a relay or somthing....could this be related? any tips? Clues ? Theorys? Let them fly.....Thanks for the help!
What events lead up to the light coming on? Does it just come on randomly? BMW Autotrans are prone to failure after a lot of miles and your car is a 93, how many miles do you have on it?
It has 130k on it so not too many. Nothing seems to be wrong is shifts real smooth. light just came on after th fuel pump went out. If I dissconnect power it drives/shifts great again
Also I think that the fuel pump relay is week (pump must have been drawing alot of current) Could this be linked to a bad ground or somthing with the relay?
