Old 05-19-2005, 06:44 AM   #1
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
96+m3 control arms?
does anybody know if there will be any problems with using 96+m3 control arms and bushings? will it change the suspension in a good or bad way? are there any other parts that should be installed with these? thanks
Old 05-19-2005, 09:55 PM   #2
B_w.
anybody know?
Old 05-20-2005, 10:30 AM   #3
Deloriant
I recently had to replace my control arms...so I put m3 ones in. The steering is a TAD bit tighter, but it's so slight it could be placebo. The only reason I did it is becuase my old control arms were busted. I wouldn't recommend it unless you have to replace them.
Old 05-20-2005, 12:10 PM   #4
B_w.
did you get the 96-99 control arms?
did you get the 96-99 bushings as well?
if so did you get the 96-99 strut hats?
the reason i ask is that is just had the 96-99 m3 control arms and bushings installed and then came accross some material that says this setup will create too much caster unless the offset 96+ strut hats are used as well. apperently this will also create too much oversteer.
deloriant have you noticed any negative effects from this setup without the strut hats?
i am going to pick up my car from getting the allignment done right away here and am wondering whether i should be ordering the strut hats.
95 or 96 M3 CA bushings? catalyst E36 4 02-26-2006 10:11 AM
lower control arms rawhawk E36 6 11-20-2005 12:18 PM
M3 SMG vs Mini Cooper S komodo BMW General Discussion 1 10-31-2005 11:18 AM
Front Control Arms dinan540 E12, E28, E34, E39, E60 5 10-28-2005 09:01 AM
History of the M3 komodo United Off Topic  **FOR MEMBERS ONLY** 9 06-05-2005 06:16 PM
