Old 06-10-2007, 01:39 PM   #1
neo66
Your Ride: 1995 328i touring
Unhappy Overheating
I have a E36 328i touring with a overheating problem......I have replaced the radiator as it was damaged,replaced the thermostat and housing,the water pump was checked and nothing found,there is no water loss that i can see,the top hose is hot and the bottom hse is cold,i have tried to bleed the system as i thought it might be an air lock,not sure what to do now......can some one help......
Old 06-10-2007, 02:56 PM   #2
stevo
Your Ride: 1997 318se Touring
there are lots of threads about ovrheating, use the search button at the top of this page, it could be the switch in the side of your radiator or maybe even though you tried bleeding the system it may still have air in it these cars are notoriously hard to bleed.
Old 06-11-2007, 07:37 PM   #3
Rate My Car: 106 / 337
Not hard at all to bleed. First timers usually get it wrong though.
1) Remove bleeder screw.
2) Start engine, set the heater on hot and turn the fan on full blast.
3) Rev the car at around 2500rpm, and watch the coolant and bubbles flow out of the bleeder hole. This will be messy . . live with it.
4) As you lose coolant through the bleeder hole be ready to replace it through the expansion tank.
5) Once the bubbles stop coming out, check the heater vents. If they're blowing out hot air and the bubbles have stopped, you are done. Put the bleeder screw back on. Let the car sit overnite or whatever, and check the coolant level in the morning, top off as needed.
Old 06-11-2007, 07:39 PM   #4
Rate My Car: 137 / 337
I'm curious as to how you "tested" the waterpump?
Old 06-13-2007, 05:05 PM   #5
neo66
The water pump was not tested,it was checked.....it was removed and a visual check and inspection.......no broken fins cracks i meen it looked OK......im no water pump expert but it just looked OK.....
Old 06-13-2007, 05:07 PM   #6
MTurboPower3
MTurboPower3's Avatar
Your Ride: Dont have a car yet
maybe its the air intake, afterall it takes in cold air and cools the engine but not as much as the water pump.
Old 06-13-2007, 07:07 PM   #7
^^^Huh??????
Old 06-13-2007, 07:59 PM   #8
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Ditto on that, Chrys.
Kid, do you know how an engine and all the peripherals work together?
Old 06-14-2007, 12:33 AM   #9
stevo
no disrespect intended but perhaps you should read up a little on how an engine actually works before posting nonsense statements like that^
Old 06-14-2007, 09:46 AM   #10
Rate My Car: 183 / 337
it sounds like from your original post that you actually DID bleed the system, if you DID bleed the system and it is overheating, check and see if there is anything blocking the airflow to your radiator, and also check and see if your aux fan is working
we'd need more details, does it only overheat when you are stopped in traffic or on the highway as well? does the heater blow out hot air?
Old 06-19-2007, 12:08 PM   #11
gabe_beamer
Your Ride: 1994 E325
your water pump is gone or your head gasket is cracked...
E36 Overheating. Kiterunner E36 23 02-07-2010 07:08 PM
Problems with overheating gannando E36 8 01-11-2008 09:16 AM
Overheating problems! Oh my! digismack E36 24 01-06-2007 11:05 PM
Car overheating DEATH2000 E36 13 06-29-2006 12:35 PM
Overheating. Numark318i E46 8 05-04-2006 08:54 AM
