Old 06-09-2007, 05:23 AM   #1
Belal Salem
Your Ride: BMW 325i 1995
engine performance 325
When I accelerate the car, it goes very well and quickly until it reaches about 2.25rpm then it doesn't accept any acceleration but it starts to accelerate slowley until it passes 3rpm it continue accelerating normaly in good performance,
What do you think that make the engine stop responding in this range of the rpm ( from 2.25-3rpm)?
Also, when I fix my speed to about 120 km/h (about 2.5rpm), the engine works randomly accelerate and deaccelerate when the same amount of the pedal is pushed, I feel a drag as if a cylinder doesn't recieve ignition then it recieves then not ... and so on, or as if the engine tends to stop then start and so on... but this is not what happens as I guess. and in that time I have black smoke off the exhaust.
Note: the engine is 325 single vanous (M50), automatic Japan transmision.
Old 06-09-2007, 05:43 AM   #2
3050rpm
3050rpm's Avatar
I sometimes have a similar problem, only in the 1800-2000 rpm range, where there seems to be a flat spot in the engine response, almost as it the car is fighting me to get beyond that point. Beyond that it's fine. I'm not sure what the problem might be, I heard somewhere that the solenoid to the VANOS (if there is such a thing) could be at fault, but I haven't bothered to check things out to that extent. On a more mundane level, have all the usual tune-up things been taken care of (plugs, filters, etc.) and have you tried running some injection cleaner through?
Old 06-09-2007, 08:09 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
The VANOS solenoid does exist. I'm not sure that the symptoms you are describing are due to a bad solenoid, but then again, my car doesn't have VANOS. As for the cost of one? For a 1995 M3 --> $500.
Old 06-09-2007, 05:14 PM   #4
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
are you throwing any codes?
Old 06-24-2007, 08:32 PM   #5
jromanc78
Your Ride: 95 325i
I have the same problem too
I had the Vanos Adjusting Unit and the Vanos Solenoid replaced and that didn't fix the problem.
Old 07-01-2007, 06:45 PM   #6
EuroStyle
Your Ride: 92 325i
when my car did that it turned out to be a faulty o2 sensor. 150.00 to replace it, and the car ran fine.
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 30 04-14-2012 10:12 AM
Supercharge? e_andres55 Forced Induction 57 05-02-2011 11:30 AM
Dressing My Engine GreenTourer Detailing and Cleaning 11 10-01-2007 10:28 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
325 Performance Belal Salem E36 7 03-23-2007 11:59 PM
