Old 06-09-2007, 04:59 AM   #1
Belal Salem
Your Ride: BMW 325i 1995
Oil leak
when I measure the oil, I found that I lose 4 litres every 2000 Km, no oil leaks visible in the motor itself, but there is a black smoke from the exhaust when I burn over 3 rpm.
325i vanos
Old 06-09-2007, 05:49 AM   #2
3050rpm
3050rpm's Avatar
If my math is correct, that's 4 quarts in 1200 miles, which in my estimation means you are now driving a diesel, for all intents and purposes. Not good. Absent any noticeable leaks, rings, valve seats, valve guides, etc. all come to mind. Not good. Also head gasket or cracked head. Not good.
Old 06-09-2007, 08:13 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
I would venture a guess at a head gasket or some sort of other engine-based seal. But black smoke is definitely not good, and is probably the reason your engine is stalling around 3 grand. But then again, if you run an engine on 2 L of oil, that's not to good for it either.
Old 06-09-2007, 08:48 AM   #4
stevo
Your Ride: 1997 318se Touring
sounds like worn or badly gummed piston rings to me, or perhaps valve seals , if the engine revs to 3,000rpm then struggles and blows black smoke it is forcing oil into the combustion chamber and trying to flood the plugs hence the vast amount of oil being used. I would seriously consider a replacement motor rather than consider the other very expensive alternative, unless of course you or someone you know is a first class mechanic.
I'm leaking oil, any suggestions nick_318is E21, E30 27 03-03-2012 03:15 PM
Oil in coolant- oh noes! Dudesky E36 11 02-11-2010 11:44 AM
Amsoil rocks. catalyst E36 26 02-23-2006 11:35 AM
FUN oil leak xxxbimmer E36 8 12-28-2005 02:03 PM
