Old 06-05-2007, 04:06 PM   #1
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
shifter problem
hey, i just installed some rogue engineering tranny mounts, ireland engineering motor mounts, the understeer mz3 short shifter, and the modified selector rod on my 328. everything lines up fine and shifts smoothly when the car is up in the air but as soon as i lower it the bottom of the shifter hits the top of the driveshaft and prevents me from changing gears. i have heard of having to bend the selector rod to clear the guibo but never a problem with the shifter itself. any suggestions on how to fix this guys?
Old 06-05-2007, 04:23 PM   #2
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
You absolutely have to bend the selector rod on the 328. I said it previously on this board, and I will say it again for anyone coming in and checking out this thread in the future:
To install an E36/7 m coupe shifter in an E36 328, you will unequivocally, inevitably, have to bend the shifter. Otherwise, the bottom of the shifter will impact the driveshaft damnpening cover.
The solution is to take the shifter out and bend it (I just went to a Lowe's and ghetto-rigged a setup right there, in the store, in the plumbing section). Any machine shop will do it for a few bucks. The best thing is to match the factory shifter's bend (why do you think it is bent from the factory?).
Tough break, man.
Be very careful removing the shifter now, since this time around you will not have spare clips, circlips, etc. if you mess them up during removal.
Old 06-05-2007, 05:30 PM   #3
B_w.
i bought the pre bent shift kit and selector rod so it should fit perfectly.
the first time i lowered it in gear and it didnt work right. this time i lowered it in nuetral and it seems to work alright
Old 06-06-2007, 02:39 AM   #4
drz
Your Ride: E36 2.8i
So it works fine? Great.
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
Auto Shifter Arm/Knob Upgrade Rooz BMW OEM Parts Department DIY's & FAQ's 2 03-13-2008 09:01 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
740I tranny shifter problem rjleee1 7 Series (E23, E32, E38, E65, E66) 2 11-15-2006 05:19 PM
