Old 06-02-2007, 07:37 PM   #1
danny123
M3 front bumper
Whats a good M3 bumper? what company? Id like to add one to my 95' 325i. I want a good sturdy one. I dont want one that look like those cheap looking tuner car ground effects that are all torn up.
Old 06-03-2007, 04:08 PM   #2
allerac
Your Ride: 1997 Bmw 328i
http://www.bavauto.com/shop.asp
Part # : E36M3 FT BUMP
you can also look at some others, depending on if you want the identical m3 bumper or just a cool looking bumper, the hartge one i found doesn't look exactly like the m3, but i like it better. good luck!
Old 06-03-2007, 04:12 PM   #3
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
You can either get the BMW factory one from the dealership (very expensive), or a website like www.bavauto.com, www.bimmerworld.com (I think they carry them), or www.pelicanparts.com.
Personally, I recommend the high-quality, perfect fit replica sold by our friends at www.jlevisw.com. Here's a link to the bumper on their site:
http://jlevistreetwerks.com/store/BM...9fe3f76b26f94f
Old 06-03-2007, 07:48 PM   #4
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
just get a replica that is made of plastic not fiberglass and you'll be straight. mine is a replica and there are zero differences except the lip on the bottom is not separate on mine but that worked out great bc i wanted to paint the lip silver anyway
Old 06-03-2007, 07:55 PM   #5
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Mine is an OEM replica made out of ABS plastic. Very sturdy and looks great, easy to paint. Mine ran me $600 CND
Old 06-03-2007, 08:12 PM   #6
danny123
ill just look around...i guess your right, i mean no ones gonna know the difference. Hows the installation process?
Mods
Dinan Cold Air Intake
Dinan Exaust
Dinan ECU
Old 06-03-2007, 10:11 PM   #7
215BIMMER535
Your Ride: '97 328i
installation is a snap. to get it off pop out the bumper trim with a screw driver, then loosen all the tiny bolts holding the plastic on (underneath and in the wheel wells). now pop out the foglights and disconnect them. then loosen the four main mounting nuts on the front middle of the bumper and it will slide off. now swap the threaded tabs from your stock bumper to the ///M bumper, same with the foglights. pop out the snaps holding the reinforcement bar on and swap it to the new bumper. (make sure your new bumper comes with the right molding, grille, and brake ducts. -most will) installation is just the opposite. it will mount right up (plug-n-play) post pics when u get it!
DIY Changing NON-M to M bumper Rooz BMW OEM Parts Department DIY's & FAQ's 5 08-12-2007 12:44 PM
Installing front lip on M3 bumper kjprince E36 2 09-14-2006 12:16 AM
Polyurethane M3 Front Bumper komodo E36 51 12-19-2005 04:51 PM
E36 M3 Front Bumper Rooz Bmw Cars For Sale/Wanted 10 11-21-2005 09:01 PM
Where to buy M3 front bumper? 1fast325i E36 7 10-28-2005 08:48 PM
