Your Ride: 93 325IS
e-36 oil leaks
Well there seems to be several oil leaks,i was informed my valve cover was leaking,i can do that but have never been into the oil filter housing,is it common that it leaks and is it hard to replace? Thanks for any good imput!!1993 325 is
Yes it is common for the OBD1 oil filter housings to leak. There are a couple freeze plugs that will leak. You can weld them up or just replace the entire housing.
