Old 05-26-2007, 10:04 AM   #1
Originalblend
Originalblend's Avatar
Your Ride: 1995 E36 328i Sport Saloon - Manual
Question Oil question for 328i Engine
I am just about to change the oil on the bimmer an have worked out that 10w40 (fully synth) is the way forward.
The oil is very expensive £42.50 for 5l my question is how much do you need to do a full change?
Thanks in advance,
Rich
Old 05-26-2007, 11:05 AM   #2
Originalblend
Ok after an hour or so paroozing the tinterweb I found that it needs 6.9 Quarts (what ever that is) translates to roughly 7 UK L.
Old 05-26-2007, 12:05 PM   #3
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Yes, indeed. About 7 liters. Keep in mind that although the full synthetic is more expensive, you only have to change it half as often
Old 05-26-2007, 09:48 PM   #4
3050rpm
3050rpm's Avatar
Just double check the level after changing the oil, my M50 engine, production 2/95, takes 8 qts. to bring the level to the top notch on the dipstick. Why that should be I have no idea, as the owner's manual calls for 6.9.
Old 05-26-2007, 10:42 PM   #5
Rate My Car: 106 / 337
^^^You shouldn't be at the top notch. Proper level is midway between the marks. That half distance up to the top mark can take as much as a quart because the oil pan widens near the top of the pan.
Old 05-26-2007, 10:59 PM   #6
drz
Your Ride: E36 2.8i
Indeed.
Old 05-27-2007, 07:28 AM   #7
3050rpm
3050rpm's Avatar
The only problem is, putting in the 6.9-7.0 qts. only brings me to the bottom notch on the dipstick, this observed from experience.
Old 05-27-2007, 02:33 PM   #8
drz
Your Ride: E36 2.8i
Then add enough to get it to sit right in between the two notches -- not for it to reach the top one.
Old 05-27-2007, 02:37 PM   #9
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
yea my 330(m54?) says it takes 7 liters..but after a day i have to add another half quart or so to get it topped off(at middle)
also 42 euro(57$) is about what i pay. around $7.50 a quart for fully synthetic oil.
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Oil Question CAPiTUL E36 3 11-25-2006 09:29 AM
Amsoil rocks. catalyst E36 26 02-23-2006 11:35 AM
Oil change question zeaq328i E36 23 09-25-2005 05:13 AM
Oil Change Question aarontran E36 9 08-25-2005 03:57 PM
