Old 05-24-2007, 05:19 PM   #1
Chad...
Your Ride: 1992 325i sedan
Bav auto ignition coils?
Has anyone here done this? Is it worth the money? I've got a high milage E36 325i with a chip and CIA, and a slightly lean fuel/air mixture, would I really feel a difference in performance? Would I be better off with high performance ignition wires insted?
Old 05-24-2007, 06:37 PM   #2
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
unless yours dont work properly you will notice no difference
Old 05-24-2007, 07:57 PM   #3
Rate My Car: 137 / 337
What wires???
Old 05-24-2007, 10:47 PM   #4
Chad...
^^^I thought you could upgrade the ones going to the coils, guess not.
Old 05-24-2007, 11:19 PM   #5
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Coils won't make much a difference. Taht kind of mod is only for those tryng to squeeze out every last bit of power possible -- like after you already have engine mods, forced induction, etc. Stay with OEM coils.
Old 05-25-2007, 08:58 AM   #6
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
IF you HAVE to replace your coils, then, yes, go ahead and get them, but unless if you'r just replace them for hopes of performance ups, u'r wasting your money.
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 05-25-2007, 11:07 AM   #7
drz
Your Ride: E36 2.8i
+1
Old 06-03-2007, 08:03 AM   #8
jdgoff
Location: SW corner of CO, live in country near village called Mancos
Your Ride: 1992 325i & 2004 325xi
I needed /wanted to replace my coils anyway, so I used these because they are less expensive than the OEM's. I had already installed a performance chip, a cold air induction, and general other regular maint/replacements, eg., belts, hoses. I use Bosch platinum 4 plugs. Many folks seem afraid of these, thinking one of the electrodes will fall off and be sucked into the engine. My neighbor is a BMW service tech, and says these plugs are used all the time without any trouble. Anyway, the description of the coils in question says the windings have been increased. Since coils are really a form of transformer--raising 12 volt to several thousand--there should be an expected increase in the secondary, or spark, voltage. Now, if your plugs are old, or fuel/air mix is not optimal, etc. the increased spark voltage may be noticed, with an improvement in engine performance. However, it may not be clear whether the 'improvemnt' is caused by new coils or by just having replace the plug to coil connector. If you've had oil leaks from the valve cover gasket into the plug wells, then these connectors may by leaking current providing less to the plug gaps themselves. In fact, over time, this kind of oil leak/spark leak will destroy the coil. So, I suppose it just comes down to whether one wants to spend the money. I don't have an unlimited budget, so I had to think about it a long time before I replace mine. My neighbor was no help, since he is devoted to OEM parts only. Hope this makes sense. I am glad I did the change. It may be only wishful thing on my part, but I to seen to recognize an improvment in engine performace while under load, eg uphill or accel. where internal cyl pressure would be higher.
Regards, James in Colorado
Old 07-02-2007, 07:00 PM   #9
Rate My Car: 106 / 337
Okay, just installed mine tonight . .
Definitely an improvement, a solid, stable idle, and the throttle is a lot more responsive. My gas mileage seems to have picked up as well, by about 2-3mpg. However, I think the jury is still out. The coils I replaced were pretty old, so who's to say that I wouldn't have gotten the same improvements with new OEM coils? I do know that these BavAuto's are on sale, and that's why I got them.
On another note, I wonder why BavAuto stamped their logo on upside down?
Old 07-03-2007, 02:20 AM   #10
maximk2
Your Ride: 1993 325i
[QUOTE=Dudesky]
/QUOTE]
beautiful coils man. under 300 bucks too. I got 220000 kms on my car. do you think it's about time i get new ones in?
Old 07-03-2007, 05:39 AM   #11
B_w.
they look nice...too bad they are covered up most of the time. i wouldnt bother repalcing the coils unless you are having problems...
Plasma Ignition System Rooz E36 25 03-15-2006 10:58 PM
High performance Ignition coils Rooz E36 33 03-06-2006 03:48 PM
Pics from Bav. Auto Show & Shine EnvyM3 Video and other Multimedia 12 10-17-2005 10:14 AM
Something New At Premium Auto Care Dwayne@PremiumAutoCare Detailing and Cleaning 1 09-19-2005 11:55 AM
Worst Cities for Auto Theft komodo United Off Topic  **FOR MEMBERS ONLY** 1 09-05-2005 01:30 PM
