Old 05-18-2007, 12:25 PM   #1
gout33
Your Ride: 93 325IS
325is clutch slipping
question?? 1993 325is clutch is slipping how do i check to see if the clutch master /slave cylinder is working properly? Thanks
Old 05-18-2007, 01:14 PM   #2
Rate My Car: 84 / 337
If it hasn't been done more than a few times (not sure how many), adjustments can be made
Edit: As far as I know
Old 05-18-2007, 01:27 PM   #3
Rate My Car: 183 / 337
maybe you speak of something i dont know, witeshark, but as far as im concerned there is no adjustment, check your clutch master/slave cylinder
Old 05-18-2007, 07:55 PM   #4
Rate My Car: 106 / 337
^^^Yes, hydraulic clutches automatically take up the slack. But if the disc is worn down pretty bad you'll get slipping. Cheapest clutch kit I've seen is from AutohausAZ for $217.
Your clutch should be engaging somewhere about halfway to 3/4 down to the floor, if it's catching closer towards the top of the travel, then your clutch disc is wearing. I think your first step should be to replace and bleed the brake/clutch fluid, check for any leaks in the cylinders and lines. A spongy feel to the pedal usually indicates air in the lines. Both cylinders are probably still okay; when they fail, the pedal will just fall to the floor and not return because the cylinder can no longer build pressure. Also listen for any weird sounds inside or outside the car when operating the pedal, that may give you some clues.
FAQ: How the clutch operates Dudesky BMW OEM Parts Department DIY's & FAQ's 10 07-09-2006 11:25 AM
Clutch slipping? Tochenzo E36 41 02-21-2006 02:29 PM
Clutch Issue? dinan540 E12, E28, E34, E39, E60 19 10-24-2005 12:05 PM
Clutch Install pics! 56k...nah devinwwu E12, E28, E34, E39, E60 4 08-04-2005 04:34 PM
Just ordered a LW Flywheel and Stage 3 clutch devinwwu E12, E28, E34, E39, E60 5 08-02-2005 11:40 AM
