Old 05-07-2007, 01:42 PM   #1
jonspencer_1981
Your Ride: 1998 316i SE
Smile key fob re-programming
I'm going to buy a newish key fob with remote locking integrated into the one housing
I am going to replace the blade with my current one, but need to re-map to my central locking/ alarm.
Does this have to be done at a main dealer, or can it be done by myself?
Also, slightly off topic, my oil service light says I'm nearly due. If I change filter and fluids myself, does this reset or it a main dealer job?
Thank in anticipation,
Jon
Old 05-07-2007, 02:49 PM   #2
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
I've never seen or heard of this being done before.
You have an e36, that is a key to an e46.
The e46 key has an EWS chip, so I don't know if you can do that.
If you are due, you can do it but the service lights won't go away until you take it to the dealer or get a special tool to switch it off.
If you are doing all this stuff, you should take it to the dealer...it would make things alot less complicated. And if they screw up, they'll fix it for free.
Old 05-07-2007, 11:06 PM   #3
chris325i
i know that my e36 can reset codes itself in the computer. i found this out when my battery blew up and when i put another one in my car wouldnt start and this after market alarm i didnt know i had kept going off. so when i found the toggle for the alarm i turned it off, then i turned my switch on and pressed the code button in the dash computer followed by the reset button. this starts a count down from 15 minutes. when it gets done you set the time and date and stuff and then itll start up. so if you do the oil yourself take your battery cable loose for a minute and then hook it up and do the code reset, it should set everything without a tool. as for the key, let the dealer do it. thats the best way to go i think.
Old 05-07-2007, 11:29 PM   #4
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
That's an E46 key.
Old 05-08-2007, 01:58 AM   #5
Niggles
Your Ride: 1992 320i
I think you can reset your service lights by earthing out pin 7 on the onboard plug in located in your engine bay, turn ignition off and earth out pin 7 then turn ignition on but don't start the car and count to 15 secs then turn off ignition and remove earth wire from pin 7.. as for the key sorry can't help you there.
Niggles UK
Old 05-08-2007, 03:58 AM   #6
jonspencer_1981
thanks folks, i understand that the key is for an e46, but want to keep the blade from mine, swap onto this casing and programme for my alarm system (still factory fit, btw)
Old 05-08-2007, 11:10 AM   #7
drz
Your Ride: E36 2.8i
Well, let us know if it works. Take pics and make your very own DIY!
Old 05-08-2007, 05:10 PM   #8
jonspencer_1981
will do. hey, drz, anymore info on the radiator temp switch?
Old 05-09-2007, 03:53 AM   #9
morroman
Your Ride: 1992 325i Saloon
Mad retrofit if you can pull it off. Give us a write up of it if you manage to pull it off. Good luck
Gotta love the e36 325i, I know I do.
Old 05-09-2007, 10:08 AM   #10
drz
Your Ride: E36 2.8i
Haven't taken pics of my engine bay. You will hate me for this: the main reason is that my camera needs new batteries
Old 05-10-2007, 05:32 AM   #11
jonspencer_1981
ha ha
nevermind, same with me actually (i did say i was going to take pics too)
I'll get them up soon as!
Key wouldn't come out CAPiTUL E36 12 05-01-2006 06:10 PM
Rants on OS X and Installing Gentoo on my Powerbook komodo Geek Chat 18 04-22-2006 03:16 AM
BMW # Key Rings Dudesky BMW General Discussion 7 01-10-2006 04:48 PM
EWS module faulty? Key reprogram? singring E36 2 01-08-2006 04:37 AM
Driver 's door key lock problem singring E36 2 12-29-2005 06:04 AM
