Old 05-06-2007, 08:20 PM   #1
kevinl34
Your Ride: 1994 325is
Unhappy PLEASE HELP serious climate control issues 1994 325is!!!!!!!!
Ok so I have change the climate control like 3 times already thinking it was the unit itself and all three times the samething happen her we go: When I turn on the the lights with the fog lights on the unit will work flawless while idleing on setting (4)full blast and 3 of the control unit. But when I turn just the fog lights on it will work on setting (4)full blast but on setting 3 it will work for a while then shut off. I have also notice while driving and the control unit working on setting (4)full blast with a/c the light tend to flicker sometime like something is pulling power from them for a moment. so heres my problem any suggestion. could it be the wiring harness were can I get this checked out because it seems something is crossed up. thanks for any help!
Old 05-06-2007, 08:32 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Replace your blower resistor. Follow the link in my signature. It has all the information. You'll be fine.
Old 05-10-2007, 01:55 PM   #3
kevinl34
ok back to the drawing board, well I replace the blower resistor today because someone told that might be the problem well..... it wasn't. Althought I can rule out its the climate control unit and the blower resistor. But I found out something funny today when the lights are on the ac still work on full power but when I turned down the power to 3,2,or1 it shut off. But then I began to notice everytime I came to a complete stop the unit would jump on, on level 3,2,1. I'm thinking now it might be a wiring problem. Has anyone experienced wiriing problems with the climate control unit like this? And if so what did you have done? THanks
Repairing climate control unit SHAHAB323IS BMW OEM Parts Department DIY's & FAQ's 16 08-18-2010 05:22 PM
1994 325IS Buying question (Canada) yuanchen E36 9 05-30-2007 09:06 PM
325is climate control problems!!!!! kevinl34 E36 4 05-03-2007 04:01 PM
Fix your analog climate control backlight Dudesky BMW OEM Parts Department DIY's & FAQ's 1 11-06-2005 08:01 PM
1994 325is w/mods FOR SALE kennasbimmer Bmw Cars For Sale/Wanted 13 09-16-2005 11:56 PM
