Old 05-06-2007, 06:54 PM   #1
Butterfly
Your Ride: 1995 325I
Coolant
I keep needing to refill my coolant so I'm guessing its leaking though i never see marks under where i park. This something I can fix my-self or should i just put it in a shop?
Old 05-06-2007, 07:34 PM   #2
Rate My Car: 106 / 337
Way too open ended- not enough information for anyone to give any sort of advice. Any telltale signs of dried coolant in the engine bay? Any smell of coolant? Can you trace it further? Tailpipe billowing white smoke? Motor running okay? How's the temp gauge? Heater works well? Are you handy with tools?
Old 05-06-2007, 10:23 PM   #3
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Just get a new car.
(or maybe give us more information so we can help you out )
Old 05-06-2007, 11:33 PM   #4
Rate My Car: 183 / 337
what it probably is is a gasket somewhere, so it only leaks when the car is hot and there is pressure in the coolant system, it could also be your heater core, turn on your heater and see if you can smell anything and see if after a while you lose coolant
also, how rapidly are you having to refill?
Old 05-07-2007, 09:35 AM   #5
3050rpm
3050rpm's Avatar
Your heater valve could also be crapping out. I was having coolant loss but couldn't find anything on the ground, and oil analysis should nothing leaking that way. Eventually I did see some coolant on some hoses in the engine compartment and traced it back to the heater valve, right by the firewall. Apparently the leak was large enough to result in cooland loss over time, but small enough not to hit the ground, and only be dissipated while driving. I can't recall what I paid to replace the heater valve, maybe $250 parts and labor, and while supposedly it's a DIY job, I found getting to the valve was a real p.i.t.a. I think my mechanic had to get at it from underneath the car. Anyway, that was the problem in my case, and as with other cooling system-related problems with these cars (water pump, radiator) it's not all that uncommon.
Old 05-07-2007, 09:55 AM   #6
Butterfly
Sorry I cant give you that much information, I just don't know that much. Ive refilled it 2 times this past month and a half. I'll try doing some of the tips you said, maybe have a friend look at it thanks.
Coolant Leak, Fuck (long post) dinan540 E12, E28, E34, E39, E60 13 03-22-2008 12:25 AM
Overflow Coolant cap on E36 Mercenary(FH) E36 10 04-06-2007 10:31 AM
Coolant Level Mercenary(FH) E36 5 10-27-2006 02:37 PM
Coolant bleed problem - 1997 540i zole2112 E12, E28, E34, E39, E60 7 10-23-2006 06:55 AM
Coolant Flush komodo E36 7 04-27-2005 09:48 AM
