Old 05-03-2007, 02:47 PM   #1
bigbull
Your Ride: h reg 318i and m reg 525i
brake light help
i have just got ma 318i back running and the brake lights are not working i have changed the fuses and checked the bulbs can any one suggest what else i can check
Old 05-03-2007, 02:57 PM   #2
Rate My Car: 84 / 337
How about the switch on the pedal?
Old 05-03-2007, 03:00 PM   #3
Reddots89
Your Ride: 96' 328ic, 01' Honda s2000, 97' vw jetta
it should be the break light switch which is on your brake pedal. i had the same problem and bought a new one for like 20 bucks off ebay
http://cgi.ebay.com/ebaymotors/NEW-B...spagenameZWDVW
Old 05-03-2007, 03:40 PM   #4
bigbull
i am from the uk people
Old 05-03-2007, 03:50 PM   #5
Reddots89
sorry just trying to help. i dont know what to tell you as far as buying one since i live in america.....but that switch is the problem so just search
Old 05-03-2007, 04:28 PM   #6
bigbull
if i wanted to check it where on the pedle will it be
Old 05-03-2007, 04:37 PM   #7
Reddots89
it should be at the top of the pedal shaft or whatever you want to call it. if i remember correctly, you have to take off the bottom dash panel. then you should be able to see it. its plastic and the pedal pushes it in when you press it. mine was hard to get out, i remember having to break the switch out of its bracket because it would not come out. good luck
Old 05-03-2007, 04:42 PM   #8
bigbull
thank you for all your info guys i wish some of you lived ova here in the uk so you could come and give a hand
Old 05-04-2007, 06:35 AM   #9
stevo
Your Ride: 1997 318se Touring
I live just over the other side of town mate, if you need help just holler I will do what i can for you. I think these other guys are right it probably is the brake light switch.
do a search on ebay; Item number: 300104674207
Old 05-04-2007, 02:38 PM   #10
bigbull
thanks stevo for that i just done a serch and its got it up right away you are a life saver m8
Old 05-04-2007, 03:25 PM   #11
stevo
no problem mate,
Old 05-04-2007, 03:46 PM   #12
bigbull
stevo you could come up some time and have a look at them and do u want my msn and ma number
Old 05-04-2007, 07:58 PM   #13
stevo
Yep just pm me the details i will get in touch with you, working right now (nightshift till 6am)
Brake Light Failure eavery19 E36 14 09-09-2011 08:30 AM
brake pad warning light DEATH2000 E36 13 11-15-2007 08:14 PM
brake sensor light on dash 215BIMMER535 E36 13 03-01-2007 04:25 AM
Brake check light wb00 E21, E30 4 01-23-2007 09:53 PM
Brake Light Circuits cruzn4abruzn E36 4 08-14-2005 12:36 AM
