-   -   Rotors (http://www.unitedbimmer.com/forums/e36/11108-rotors.html)
Butterfly 05-02-2007 06:56 PM
Rotors
Alright I'm replacing my front rotors and pads, but was warned about bmw's leaking it's brake fluid into the system and breaking it. Now how is this prevented? i plan to follow the guide on this forum and having a friend who has done a few German cars but never a bmw.
thanks
RSF5 05-02-2007 07:23 PM
I haven't heard a lot about BMWs leaking brake fluid...?
NavyL7 05-02-2007 07:32 PM
what do you mean by "leaking brake fluid into the system and breaking it" ?? Do you mean leaking from the calipers?
mullethunter3 05-02-2007 07:39 PM
Yeah, in my experience, the fluid system is very tight and sound. I've been in there twice on two different car and can't seem to think of a place that might leak fluid and "break" the system.
RSF5 05-02-2007 08:04 PM
Anyone else heard of this??
215BIMMER535 05-02-2007 08:29 PM
never. i've done my brakes twice. once was all new rotors and pads. once just all new pads. granted, theres a warning in the manuals about overflowing the reservoir when u drive the piston back in, and it overflowing..... but that is the only thing i've heard of even remotely sounding like what u said, and mine wasn't even close to overflowing. take your time, follow directions, and you'll be fine. the brakes on these cars are really simple
Butterfly 05-02-2007 09:50 PM
alright thanks for the help.
drz 05-02-2007 10:33 PM
Be sure to follow the directions in the DIY -- do not let the calipers hang on the brake lines, because THAT could break them.
ENjoy bimmerDIYing :)
jdgoff 05-07-2007 09:37 PM
What year? My 92 has brakes just like nearly all other production disk types. I've done my front brakes 3 times, and last time replaced flex hose with after market stainless protected hoses. Need one on each side. Otherwise, I think std OEM hose replacement should be OK. Your friend should find his experience can be safely used on BMWs. Do be careful not to cross thread hard and flex hoses. Also I suggest you use flare nut wrench on fittings. These are not very expensive, and available at most parts stores. If you do replace hoses, you must bleed brake lines. Nothing tricky here if use two person technique. Ask friend. Sequence FR then FL, if only front axel replacement.
jdgoff 05-07-2007 09:42 PM
Had another thought. Check caliper cylinders for leakage. If they leak, should see brake fluid all over. preventative maint. would be to replace or rebuild. It is a messy job, and I wouldn't recommend it unless you have tech manual and sufficient tools.
