Old 05-02-2007, 12:10 AM   #1
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
Climate Control Failure
What up guys, i haven't been around for a while. I was driving across campus yesterday, the air was on medium temp and force (i guess thats what you would call it), and it randomly shut off, the lcd display went black and air stopped coming out of the vents. however, the lights on the sides; like the foot, defrost, face buttos were still lit up in green. a minute later it turned back on again. then i turned it to full air and it stayed on for 30 seconds and shut off yet again.....Have any of you heard of this happening before? if so, what would be the solution?
Old 05-02-2007, 01:57 AM   #2
stevo
Your Ride: 1997 318se Touring
same thing happened to me a couple weeks ago, take a look here it might just save you a few $$.
http://www.macadamizer.com/bmwfix.html
alternatively you could take your module to a good electrician and have it thoroughly checked over to see if there are any loose connections.
Old 05-02-2007, 10:44 PM   #3
BaLAnCe17
BaLAnCe17's Avatar
anyone else heard of someone having this problem? dealership price for the fix? thanks
thanks for that link btw stevo...i just probably shouldnt pull that thing out and start souldering
Old 05-03-2007, 01:17 AM   #4
stevo
Here in the uk the main dealers will NOT fix a faulty unit, they just try to sell you a new one , cost around £200.( about $380)
Best advice i can offer ,if your module gives up totally take it to a reputable auto electrician along with a print out of the page i gave you the link for.
If you attempt to fix the module yourself do not use a blade to remove the lacquer as it can damage the circuit board beyond repair, use nail varnish remover or paint stripper.
I bought a replacement module from ebay £70 ($130), fitted and working no problems.
Or if you look on ebay there might be one or two people who repair these units for a very reasonable price in your part of the world, there is in the uk.
Old 05-03-2007, 01:22 AM   #5
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
This is one of the most common E36 bugs. The dealer's fix is called buying a new one and paying to get it reprogrammed to display Fahreanheit instead of Celcius, and should cost you about $600.
Old 05-03-2007, 01:24 AM   #6
BaLAnCe17
BaLAnCe17's Avatar
haha figures. i just got a soldering gun...so its on for tomorrow
Repairing climate control unit SHAHAB323IS BMW OEM Parts Department DIY's & FAQ's 16 08-18-2010 05:22 PM
325is climate control problems!!!!! kevinl34 E36 4 05-03-2007 04:01 PM
RSM failure and Subframe failure 94bmw325i E36 22 10-25-2006 10:28 AM
Fix your analog climate control backlight Dudesky BMW OEM Parts Department DIY's & FAQ's 1 11-06-2005 08:01 PM
