Old 05-01-2007, 03:07 PM   #1
dinohm4
Your Ride: 1993 325i
Exclamation Why Would it overheat
I recently replaced the head in my e36 got it remachined and everything should go back to normal. when i was at the red light the temperature gauge went beyond the middle where it's usually at. So i was wondering if it could be the fan clutch?
DINO:
Old 05-01-2007, 03:24 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Its not leaking coolant and the water pump is working?
Old 05-01-2007, 06:25 PM   #3
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Is the electrical auxiliary fan working?
Old 05-01-2007, 07:05 PM   #4
Rate My Car: 106 / 337
The first question is always: was the cooling system properly bled? Taking a cue from drz, is the fan switch connected? You sure you put everything back the way it was, everything hooked up properly?
Old 05-01-2007, 08:37 PM   #5
Rate My Car: 137 / 337
Plus - why did you redo the head in the first place? Overheating? I hope you used a new thermostat & gasket after head work.
Old 05-01-2007, 08:51 PM   #6
RSF5
RSF5's Avatar
yeah
Old 05-02-2007, 09:47 AM   #7
dinohm4
Yeah i remachined the head because it was messed up. the car does not leak coolant, the water pump in new, new thermostat and new head gasket set. so i tought it could be the fan clutch which is pretty much a year old. but the auxliary fan i have never seen it working.
DINO:
Old 05-02-2007, 10:43 PM   #8
drz
Your Ride: E36 2.8i
The auxiliary fan should turn on whenever you turn on your air conditioning, regardless of the temperature outside. Try turning on your A/C and see if the fan turns on.
Old 05-03-2007, 08:44 AM   #9
dinohm4
The fan is working properly i just changed one of the fuses and it;s working good. what are the sings of a faulty thermostat? does any one have am idea of how i can test for this
DINO:
Old 05-03-2007, 08:47 AM   #10
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
im not sure you can test for that.
i would recommend that if you change the thermostat swap out the water pump at the same time.
generally bad thermostat=always cold(broken open) or it over heats..(stuck close)
Old 05-03-2007, 08:53 AM   #11
Sign of a faulty t-stat is if the car takes a long time to reach normal operating temp. Your needle should be at the halfway point within 5-10 minutes of driving. Also check the top radiator hose. Pressure and coolant flow should exist there once operating temp is reached, if the t-stat is opening properly.
Old 05-03-2007, 09:34 AM   #12
dinohm4
does anyone have instructions on how to change the thermostat
DINO:
Old 05-03-2007, 09:39 AM   #13
Old 05-03-2007, 09:53 AM   #14
dinohm4
Thanks for the site man, hey how possible is it that a brand new thermosat mess up that quick, i mean teh one i put after all the work is brand new and i wonder why it would mess up that quick
DINO:
Old 05-03-2007, 10:20 AM   #15
I'll bet you t-stat is fine, and you just have trapped air. Are you sure you bled the system thoroughly?
