-   -   Removing Yellowed Coating On Engine? (http://www.unitedbimmer.com/forums/e36/11041-removing-yellowed-coating-engine.html)
philt80 04-28-2007 02:36 AM
Anyone have any idea how to remove the yellowed lacquer looking coating from the engine(see below)?
http://i85.photobucket.com/albums/k56/Foozah/engine.jpg
And is there some kind of new protective coating to replace it once it has been removed?
celsdogg 04-28-2007 09:04 AM
that was probably from a detailing or something.
mullethunter3 04-28-2007 11:28 AM
It's from spilled oil. Burnt spilled oil to be specific. I've been told that WD-40 works... I've tried it with no avail. If you find something, let me know.
nick_318is 04-28-2007 12:07 PM
try some good degreaser
mullethunter3 04-28-2007 12:18 PM
^^^ I tried that with steel wool. No luck. Anything else?
Also, engine detailer doesn't work. I tried a bunch of things before Midwest Bimmer Festivus last year...
nick_318is 04-28-2007 01:07 PM
I have heard people say good things about simple green.
mullethunter3 04-28-2007 01:19 PM
Sweet, thanks. I will try that once I get home in a week and a half.
philt80 04-28-2007 02:08 PM
let me know how it goes Amanda....
if it works I'll give it a go on mine
mullethunter3 04-28-2007 02:18 PM
Will do.
Dudesky 04-28-2007 03:45 PM
Just a thought, don't know if it'll work- you could try GoJo orange hand cleaner. It's an excellent degreaser, we use it to clean grease off steel at work.
Ultimately, you could send the cover out to get sandblasted next time you replace the gasket. Doesn't cost too much, maybe $50 tops, if it really bothers you.
c1apton 04-28-2007 06:09 PM
That's a factory coating to keep oxidation to a minimum. If you really want it off bad enough use spray aluminum wheel cleaner (for non clear cote wheels) that's an acid you spray on rinse off.
brien4787 04-29-2007 05:42 AM
you can scrap it off.... takes forever..
maximk2 04-29-2007 02:14 PM
just put some makeup on it.
Numark318i 04-29-2007 09:45 PM
i have the same problem with my 318. heh same engine ftw.
anyways..i took a dremel to it for like twenty minutes...got one intake manifold finished...and said screw this.
