Old 04-18-2007, 07:34 PM   #1
David Daniel
Your Ride: 1992
1992 381i Sedan Engine Problem
On my 381i when starting it sometimes it seems to backfire and blow off the upper or lower idle control valve hoses. The last time it did this it blew a hole in the Air Mass Meter boot. I am not sure what is causing this problem. This is intermittent and varies how often in consesion it happens. Any help is apprciated.
Thanks!
Old 04-18-2007, 09:27 PM   #2
Rate My Car: 183 / 337
just from the backfire it sounds like you have a timing problem, how does the car run otherwise?
Old 04-19-2007, 10:33 AM   #3
David Daniel
Your Ride: 1992
The engine runs fine once it starts and the hoses stay on!
Old 05-07-2007, 09:25 PM   #4
jdgoff
Location: SW corner of CO, live in country near village called Mancos
Your Ride: 1992 325i & 2004 325xi
sometimes a backfire thru induction is caused by lean mixture--at least in normally aspirated motors. Since mixture is controlled by OB computer, which relies on input from a number of sensors, diagnosis may be difficult without proper instrumentation. Swapping parts is usually not a good way to work, but you might want to test/replace Oxy sensors.
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Engine Problem?? petethemanc E36 11 04-19-2007 02:47 PM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
Engine Management Problem barry E46 7 04-08-2006 12:30 PM
