Old 04-18-2007, 05:09 AM   #1
micky
Your Ride: 92 E36 M40
Instrument lights aaargh
Help ..e36 318.. Globes ok, fuses ok, but no Instrument lights . The Dimmer control is hot/warm, is this the culprit.
Does any know which points to check with a multimeter to pinpoint the problem.
Old 04-18-2007, 01:01 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
If the switch is warm, maybe there is something grounding out somewhere? I would pull the cluster out and see. To pull it out, follow the instrument cluster light DIY in my signature. I don't have too much info to go on...
E39 - Resetting the service indicator lights e39 bimmer E12, E28, E34, E39, E60 16 03-14-2012 03:38 PM
DIY: Replacing Instrument Cluster Lights mullethunter3 BMW OEM Parts Department DIY's & FAQ's 41 01-06-2008 02:16 PM
Spot lights misting up inside GreenTourer Lighting 0 02-18-2007 11:42 AM
How to change bulbs in the instrument cluster Bimmersrbest E36 8 05-31-2006 04:41 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
