Old 04-14-2007, 04:33 PM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 285 / 337
Your Ride: 1993 BMW 325is
Vibrating Noise from Shifter handle (when backin up)
So I noticed when it's cold. u can hear this like....virbrating noise, that almost sounds like it's coming from the shifter handle (it's an auto bmw 325is 93') but it's only whens it's like cold outside? and after I drive it for awhile it goes away. but it's only when Im backing up?
any ideas
Old 04-14-2007, 06:06 PM   #2
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
cars never run perfectly till they warm up
Old 04-16-2007, 08:56 PM   #3
Mercenary(FH)
......anyody else any clue
Old 04-16-2007, 10:32 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
might want to swap out the tranny fluid.
Old 04-17-2007, 12:05 AM   #5
Mercenary(FH)
. i suppose....but swapping out fluid on bmw's is an expensive ordeal. and .i dont think the fluid would cause the shifter handle to shake like that? since my car shifts fine, it just makes that weird noise
Old 04-17-2007, 04:16 AM   #6
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
A fluid change is only expensive if you go to the dealer. I did mine a few weeks ago and it ran me about $35-40 for seal, filter, and fluid (plus shipping). Do it yourself, takes maybe half an hour (1st time) and saves $$
Old 04-17-2007, 12:56 PM   #7
Mercenary(FH)
but why would fluid cause it to vibrate....but only do it when u are backing up?
Old 04-17-2007, 01:37 PM   #8
Numark318i
Numark318i's Avatar
Your Ride: ^^
reverse gear has gunk on it?
I really have no clue. just thought i wuld thorw the idea ot there.
try it..you should do it eventually anyways.
Old 04-17-2007, 09:51 PM   #9
Rate My Car: 183 / 337
the reverse gear ratio is very different from your forward gears, actaully it is a little bigger than the 1st gear i think, but as an automatic, your car should always start out in second gear anyway, unless you floor it
Old 04-18-2007, 01:36 PM   #10
Mercenary(FH)
do u think it has anything to do w ith that gear then....for some reason when it's cold?
Old 04-18-2007, 01:42 PM   #11
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Thermodynamics?
Old 04-19-2007, 09:31 AM   #12
Montizzle 325i
Your Ride: 1998 dakar ///M3 sedan 5-spd
change the fluid. That way if it DOESNT fix the problem, at least your fluids are changed plus, its one step closer to finding out what it is. Its not even worth continuing to guess until you start troubleshooting and narrowing things down
Old 04-19-2007, 02:27 PM   #13
B_w.
does it seem odd to you that it would vibrate a little bit? there are lots of moving parts so some vibration is normal...i wouldnt worry unless its actually sounds bad...change the fluids and see if that helps.
based on you past posting history it is easy to see that you over analyze stupid shit and make too many threads about it...
if you can just feel the vibration through the shifter its probably normal. does anything sound different?
Old 04-20-2007, 10:18 AM   #14
Mercenary(FH)
no i mean yeah it's vibrating but u can hear it.. outside of the car too, it sounds like it's coming from under the handle. like it's hard to describe but it's like intermittent, like if U had a baseball card attached to your bicycle wheel? know what i mean?
but i mean it only does it when it's cold outside, and after driving for a lil bit it goes away?
i was thinking, my e-brake handle doesnt work anymore (as in when i pull it up it doesnt lock (the button is smashed in )
could this possibly have anything to do with it?
Old 04-20-2007, 03:43 PM   #15
B_w.
maybe its time to bite the bullet and put a real tranny in there
Auto Shifter Arm/Knob Upgrade Rooz BMW OEM Parts Department DIY's & FAQ's 2 03-13-2008 09:01 PM
