Old 04-12-2007, 10:09 PM   #1
kvadgama
What to Expect at 165K?
Just wondering what I can expect that will break on my E36, 328i 1996.
Here's what happend so far.
100K miles - radiator replaced
130k - Water pump replaced
145K - control arm and power steering hose.
160K - fuel pump replaced
Currently I have 168K miles and wondering what else I can expect.
Some stuff that comes to mind is starter, alternator etc.
Appreciate any inputs from your personal experience.
Thanks
Old 04-12-2007, 11:15 PM   #2
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
I bought my 1996 328i with 169k miles on it. I have since replaced the auxiliary cooling fan, rear lower control arm, alternator, and would probably benefit from a new steering rack. I have power steering hoses and brake lines waiting to be installed. I will soon also have the RTABs and LCABs done.
You may want to replace teh fuel filter just for peace of mind.
Other than that, just keep your fluids, filters, and brakes changed regularly. You should be golden. I am now at 203,500 miles.
Old 04-12-2007, 11:30 PM   #3
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Replace your filters and check compression maybe. Replace hoses, you sound pretty good to go.
Old 04-12-2007, 11:44 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
yea i would say vacuum hoses also.
you generally cant tell they are falling apart unless you take them out and really take a close look.
Old 04-13-2007, 12:09 AM   #5
straight6pwr
Rate My Car: 26 / 337
yes watch for drying/cracking fuel hoses. i had one split open on my e30 at 160k and needless to say, im lucky a fire didnt start.
Old 04-13-2007, 07:22 AM   #6
3050rpm
3050rpm's Avatar
You've got a pretty good handle on it, as well as the already mentioned suggestions (my alternator went at ~140,000). A few others, and putting the car up on a lift would help: check brake and fuel lines and their connections; certainly check battery twice a year and add distilled water if necessary; flush power steering fluid; if not already part of your maintenance schedule, flush entire cooling system, replace differential oil, transmission fluid (manual or automatic); check wheel wells, rocker panels, and lift pad points for corrosion; shocks and struts may be on the list too, depending upon your preferences, and if so check the accompanying bushings and linkages; if you've got oil accumulating in the spark plug wells, then the gasket should be replaced; 02 sensor may need replacing (my car failed a recent emissions test without the check light coming on, but the mechanic diagnosed the sensor, put a new one in, I'm legal now); and you may want to vacuum under the seats to get any stray M&Ms...
Old 04-13-2007, 01:49 PM   #7
Gordon
Your Ride: 1995 e36 318i
At a total of 200k. I have replaced: X1 thermostat
: X1 fanbelt
And ofcourse the normal maintenance required!!
Bmw Rocks bro!! My 95' 318i still puts out 105Kw all the way!!!!!
Bmw is the best quality car you can find on the market today!!!!
Enjoy them!!!!!!!!!!!!!!!!!
Gordon
Old 04-13-2007, 02:16 PM   #8
drz
Your Ride: E36 2.8i
Oh, and my catalytic converter needs to be replaced.
Old 04-14-2007, 01:48 AM   #9
brien4787
Title: DelTaco
Your Ride: e36
at 162k ish... big things have been an alternator and starter... good luck! unhappy spending!
Old 04-14-2007, 01:57 PM   #10
drz
Your Ride: E36 2.8i
Originally Posted by brien4787
unhappy spending!
lmao
Old 04-19-2007, 05:06 PM   #11
ClassicE36Bimmer
ClassicE36Bimmer's Avatar
Your Ride: 1997 328i Sedan w/ Sport Package
Good post. I have a 1997 328i at 120,000 miles.
Now I know a little bit of what to expect.
Old 04-26-2007, 09:35 AM   #12
NavyL7
Your Ride: 1997 328is
I agree 'Classic', Good topic, I just picked up a 328is w/123,000.
