Old 04-03-2007, 10:51 PM   #1
jbettini
Question E36 Thermostat temp ?
Hi gang, glad to have found this group.
As seems all too common, I have an overheating issue with my 95 325i. Before bleeding the system I want to replace the thermostat. Only question is, what's the correct 'stat temp for my daily driver?
Also, there'a s hell of a lot of stat manufactures. I know there's some less then reliable products out there. Is there any one brand that I should be using?
Old 04-04-2007, 12:46 AM   #2
Rate My Car: 137 / 337
the rec. stat temp is 192-195 degrees. Any good brand name stat will work - I've had good luck with the ones from Bavauto / pelican parts.
Old 04-04-2007, 06:32 AM   #3
matimus
matimus's Avatar
Your Ride: E30/S50 GT35R+ E30M3
you can use any temp t-stat . depending on your setup and needs.
I use a 75degree, it stays really cools, but if you drive in the winter/cold weather you wont have much heat. the closer you are to 92(stock) the better your fuel economy will be.
theres 75, 81, 88 and 92 degree t-stats available.
up to you really.
change your water pump while your at it!!
For Sale Window Regulator E36 Coupe defkon99 Bmw Cars For Sale/Wanted 0 06-18-2006 10:22 PM
Fun With E36 Gauge Cluster Test Functions bitcore BMW OEM Parts Department DIY's & FAQ's 1 05-04-2006 03:08 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
