Old 03-28-2007, 03:43 PM   #1
Rate My Car: 183 / 337
Wow sorry for all the stupid questions
Sorry, this has me a little bit worried
when im on the highway going between 70-80(like passing someone, and switch back to the right lane) sometimes, only when its a left turn, there is this crazy shake in the steering wheel and the wheel goes really light...
seems kinda serious to me, i was thinking something to do w/ball joints, tie rods or control arms, anyone know or has had this happen to them?
Old 03-28-2007, 03:57 PM   #2
Rate My Car: 84 / 337
Do the tires seem weirdly worn?
Old 03-28-2007, 03:59 PM   #3
no the tires are really in great condition, even wear, i dont know if they have been replaced recently and that is why, however no indication there
i plan on taking it to a shop tomorrow and seeing what it looks like on a lift, but anyone know of the top of their head what this could be(so I know whats coming at me)
Old 03-28-2007, 05:00 PM   #4
Rate My Car: 106 / 337
CAB? Throw it on the lift, that's the only way you're gonna find out.
Old 03-28-2007, 05:01 PM   #5
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
are your rims bent?
That might be the culprit.
or your tire pressure?
Old 03-28-2007, 07:52 PM   #6
well i havent gotten a chance to go to the shop yet, i was planning on doing that tomorrow, but i jacked it up today in the garage and yep, the CABs are pretty bad, i know bimmerdiy has a DIY for it, but anyone know how hard it is to replace them? do i really need a special tool to put it back on the control arm? thanks
Old 03-28-2007, 08:34 PM   #7
also, are m3 bushings better or is it really all the same thing?
Old 03-28-2007, 08:51 PM   #8
I rigged up a clamping system to push them onto the end of the control arm, but it didn't work. In the end, I slipped a large socket over the end once I got the bushing in part way, and tapped it with a hammer the rest of the way. If you don't understand what I mean, then you will once you take a closer look at the bushings. The trick is to get both of them on and the car back onto the ground withing 20min or so, but it's not that hard. The more lubricant you use, the easier the job goes.
The M3 bushings are stronger and will last longer since they're solid rubber. But I saved money and used the OEM ones and am happy with them.
Old 03-28-2007, 09:26 PM   #9
Kistoni
Rate My Car: 239 / 337
Your Ride: 316i '95
I used the oem ones and they were shredded again within six months now i am looking for urehtane ones... uuc are supposed to be coming out with a set sometime soon. my RTAB are in the post from them as I type. They do affect ride quality but are supposed to last longer.
Old 03-28-2007, 10:41 PM   #10
yea i know what you mean, the DIY i was looking at, he took his gear puller/harmonic thing or w/e and rigged it up backwards so he attatched one end ot something and when he screwed it in, the thread was attatched to a socket and pushed the bushing in
Old 03-29-2007, 05:53 AM   #11
The Understeer DIY, right? . . .
Use a large bench vice or a hydraulic press to press the new bushing in to the bracket as far as possible. Then use a hammer to "fine tune" the position of the bushing in the bracket. The bushing should be centered in the bracket with even amounts sticking out of both sides.
Here's a little easier way: Using double stick tape, I placed spacers on one jaw of the vise, so I could press the bushings beyond flush with the edge of the lollipop. That way you get them centered w/o using the hammer technique.
Old 03-29-2007, 10:20 PM   #12
hmm, well thanks for the tip, but it turns out, at a second, better look, my control arm bushings are actually in really good shape(i could have sworn i saw them torn last night) but waht it is, is that theres a lot of play in the right, lower/outer ball joint, so i just ordered two of them for the hell of it, and ill replace that and report on how it went
Old 03-30-2007, 04:51 AM   #13
Wow. Let me know how hard that is to do. When I do mine this summer, I think I'm just gonna get the whole control arm with both ball joints preinstalled
Old 03-30-2007, 04:31 PM   #14
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
xsperf what kind of car do you drive?
Old 03-30-2007, 10:12 PM   #15
i just bought a 95 325is less than a week ago
dudesky, my friend's shop that im taking it to, he does have a hydraulic ram/press, so that might be the only thing that would be difficult, either way ill probably find out monday when the parts come
Wow am I really stupid jms E36 8 05-01-2006 06:31 PM
Untapped Stupid jms Rant Forum 8 03-17-2006 09:01 AM
The election Hillary Clinton will cause the fall of America komodo United Off Topic  **FOR MEMBERS ONLY** 6 02-19-2006 08:41 PM
BMW Drives into the Fall TV Season komodo BMW General Discussion 3 10-28-2005 01:05 AM
Bulb Replacement/ and other questions. ///Menace328i E36 0 05-13-2005 10:07 AM
