Old 03-28-2007, 12:01 AM   #1
akinthecat
Your Ride: 1999 320i
Lights, camera...no action
My front fog lamps got condensation in the front left. these are cheap to replace. No problem.
however when i turn the light switch to the first 'on' position the lowlights (Dimmed lights) turn on. when i turn the light switch to full on position the main headlamps do not switch on. I had to use the fog lamp 'on' button to activate the headlamps. But the headlamps AND the fog lamps switch on. Is the wiring for these two sets of lamps connected?
I've taken a look at the light switch, all contacts good nothing broken. Took a look at the fuse box and the wiring nothing out of the odinary.
I did however remember that when the main bulb (H1) was beginning to fail, the headlamps would fail. New bulbs replaced still got this problem.
What size is the headlamps? I got 3 pairs of H1 bulbs in my car. Is 'upgrading' to xenon bulbs worth it? I know there is a separate thread for 'lightings' but i thought i might mention it here since its related to my wiring and/or switch problems.
Old 03-28-2007, 12:10 AM   #2
Rate My Car: 84 / 337
Seems like a relay problem to me
Old 03-28-2007, 03:21 AM   #3
akinthecat
How do i check that? Its in the same box with the fuses? what do i look for?
Old 03-28-2007, 05:04 AM   #4
Rate My Car: 106 / 337
I had a similar problem when I 1st bought my car, and replacing the headlight switch fixed it. You can't just look at that switch and see everything that's supposed to be making contact.
E39 - Resetting the service indicator lights e39 bimmer E12, E28, E34, E39, E60 16 03-14-2012 03:38 PM
DIY: Replacing Instrument Cluster Lights mullethunter3 BMW OEM Parts Department DIY's & FAQ's 41 01-06-2008 02:16 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
