Old 03-27-2007, 09:03 PM   #1
Vik
Vik's Avatar
Your Ride: 2000 323ci
Question Sunroof doesn't open
My father has a 1995 325i and recently his sunroof and later on windows stopped working within 2 weeks, he replaced the fuse#43 and he doesn't have the comfort relay. If you could please give an advise I would greatly appreciate it
Old 03-28-2007, 05:29 AM   #2
Rate My Car: 106 / 340
This is a guess, but it could be a problem with the Central Body Electronics (aka ZKE IV system). Check fuse #'s 7, 14, 26, 28, 31, 33, 35, & 43. Or it could be a problem with the ZKE IV module itself, located behind the glovebox.
Old 03-28-2007, 10:03 AM   #3
dinohm4
Your Ride: 1993 325i
hey i have a problem with my sunroof as well. all the electrical works except that it seems like it is stuck. when i got it it did not open all the way now it just doesnt open. the motor sounds like its working but i t just wont open anymore. any suggestions?
DINO:
Old 03-28-2007, 03:29 PM   #4
herbertcab126
herbertcab126's Avatar
Your Ride: 1996 e36 328i coupe
hi,i have no end of friends with elec sunroofs,there isnt one that hasnt had a problem with them if the motor hasnt blown,they run slow,then there popping fuses for breakfast.
i dont know if its a common bmw fault but i know at least 5 like this,it could be the motor that causes it.
Old 03-29-2007, 10:07 AM   #5
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
As for Vik, I would replace more fuses than #43, like Dudesky said. Chances are that more than one fuse controls one operation. I know, I've had some problems...
As for dino, open up the panel to the sunroof motor (it's the one by the map lights). You'll see the sunroof motor. In the center, there is an allen key. From that you can turn the motor without electronics. If you do this, you can see if there is anything in the way of the sunroof. If the "manual-motor" actually moves the sunroof, there is nothing in the way and your motor is probably bad and will need replacing. In your case, I doubt it is a fuse issue since you said that you can hear the motor trying to work, meaning that there is current getting to the unit.
F*** the sunroof!!! akinthecat E36 7 03-15-2007 11:45 AM
Sunroof question Dudesky E36 2 01-05-2006 03:46 PM
Trunk Will not Open, any ideas nick_318is E21, E30 6 08-14-2005 01:21 PM
How do I remove headliner for sunroof install? Beater_Bimmer E36 2 08-14-2005 11:37 AM
sunroof problemo brien4787 E36 8 07-12-2005 09:23 PM
