-   -   Which oil is closest to BMW oil? (http://www.unitedbimmer.com/forums/e36/10662-oil-closest-bmw-oil.html)
xsperf 03-26-2007 04:02 PM
Is it castrol GTX synthetic? just wondering b/c i really dont feel like ordering oil from bavauto :)
drz 03-26-2007 04:16 PM
If I remember correctly, that is what BMW uses. I have been using Mobil1 full synthetic for two years, if you care to know.
nick_318is 03-26-2007 06:10 PM
Castrol sounds right, I believe the dealer has given me that in the past.
Numark318i 03-26-2007 06:21 PM
dealer near me sells BMW high performance oil at the same price as castorol.
Im gonna get that next time.
xsperf 03-26-2007 09:04 PM
well i need to change my oil and i didnt wanna go with any normal synthetic b/c ive heard that on older engines it may leak, and ir eally didnt feel like going to the dealer ot buy oil or ordering oil on the internet
drz 03-26-2007 11:20 PM
synth > dino
The dealerships only stock synthetic. They use Castrol. Even the oil that says BMW on the label is rebadged Castrol.
If you're going to stick with dino oil, then youst get any good oil, either Castrol of Mobil1, and be sure to keep your oil changes regular, in the 3k mile interval.
Just to share my experience: I switched to synthetic as soon as I got the car. It had never seen sythetic in its first 169,000 miles. I have no leaks, and I only change my oil every 6000 miles or six months, whcihever comes first. I am now at 203,000 miles.
xsperf 03-27-2007 12:01 AM
Originally Posted by drz
synth > dino
well, in that case, thanks for the advice, i will probably go with either castrol synthetic or mobil 1
Dudesky 03-27-2007 04:52 AM
Don't forget your gloves :D
c1apton 03-27-2007 05:56 AM
Castrol Syntec - ftw:clap
mzbmw325i 03-27-2007 12:49 PM
my car is at 202k, recently changed pan gasket, only used non synthetic oil since its been in my hands, should i stick with it or if i change to synthetic will i see any change in engine behavior?
since synthetic is "thinner" would that be a problem for my "old" engine's seals and gaskets and what not?
thanx :adance
nick_318is 03-27-2007 02:02 PM
As an older car it is possible that you will see more leaks from the synthetic but not everyone has problems with it. I think i will keep using dino in mine until i need a new engine.
xsperf 03-27-2007 09:21 PM
heh, dont worry ill wear a jump suit too :)
xsperf 03-27-2007 09:41 PM
by the way, how much oil does the engine take, is it 6.9 quarts or 7.5?
c1apton 03-28-2007 03:22 AM
This use to be the case, but synthetics have improved and aren't as "thin". As long as your car isn't prone to burning oil and doesn't show signs of seepage, I wouldn't hestitate switching to a good name brand syn.
Dudesky 03-28-2007 05:01 AM
6.9, although I've read a thread elsewhere about a handful of people needing more . . I have no idea how that happens.
