Old 03-25-2007, 12:49 PM   #1
larryglover@gulfviewllc.c
Your Ride: 1995 E36 M50 I6
Oil covering spark plug - help!
I own a 1995 E36 M50TU I6 Saloon wit sports package which I purchased new. Recently retired it from daily driver service and am now upgrading to a muscular gentlemans sports car. Just replaced the spark plugs and did a compression check, good new is the compression is great, bad news is on a couple of cylinders oil was found around spark plug. On one of the cylinders, the chase going down to the spark plug was half full of engine oil that completely covered the spark plug. This can't be good for the coil setup.
Normally, I would just take it to the BMW dealership and be done with it. However, since retiring the car I've decided to do my own upgrades and mechanical work as a hobby. Anybody have a similiar problem and a repair solution to share?
Please let me know,
larryglover@gulfviewllc.com
Old 03-25-2007, 02:55 PM   #2
Rate My Car: 106 / 340
Not to worry, common occurence. You need to replace your valve cover gaskets. It's a 3 piece gasket set, two of which seal the chase holes. Despite the oil, the coils typically still fire no problem, believe it or not.
Here's a good writeup on how to replace the gaskets:
http://www.pelicanparts.com/BMW/tech...alve-Cover.htm
Old 03-27-2007, 04:00 PM   #3
Thanks Dudesky, appreciate the quick response. I ordered the new valve gasket which should be here soon.
Old 05-07-2007, 09:53 PM   #4
jdgoff
Location: SW corner of CO, live in country near village called Mancos
Your Ride: 1992 325i & 2004 325xi
If oil is on outside of plug or in well, then usual cause is leaky valve cover gasket. This is a typical problem with M50 onwards. It is easy and quick to remedy. Bavauto has a tech sheet showing how. Gasket is cheap. If your engine has individual coils, one for each cyl., the oil can cause coil to fail.
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
BAv-Auto Performance Coil Install. defkon99 BMW OEM Parts Department DIY's & FAQ's 14 05-10-2009 11:23 AM
Spark Plugs replaced, OIL EVERYWHERE help Mercenary(FH) E36 15 09-13-2006 02:08 PM
Oil Drin Plug andykay E46 6 05-07-2006 11:27 AM
