Old 03-24-2007, 01:18 AM   #1
Tofurki
Your Ride: 1993 325i
Grounding Wires (What do you ground it to?)
Grounding wires are suppose to be connected to the negative terminal of a battery of a a car. There is a problem here with our BMWs. The battery is in the back. How do you install grounding wires on a 325i? Will it work the same if i ground it to the metal frame of the body? Someone please help.
Old 03-24-2007, 04:44 AM   #2
Rate My Car: 106 / 337
What grounding wires are you referring to? The entire chassis is negatively grounded, and there are also several designated ground points all over the car.
Old 03-24-2007, 06:32 PM   #3
Tofurki
Im talking about if you buy a grounding kit. Not the factory ground wires.
Old 03-24-2007, 08:19 PM   #4
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Yes, just ground it to the metal frame.
Old 03-25-2007, 07:12 PM   #5
Tofurki
cool, thanks a lot
93 E36 DME and ground magic panorama E36 12 12-10-2010 03:11 PM
E30 Stock Headunit/Stereo to Aftermarket celsdogg Car Audio and Electronics 7 09-25-2007 03:35 PM
audio crossovers..help me Numark318i Car Audio and Electronics 15 12-14-2005 05:22 PM
shitty sound..advice? Grounding.... Numark318i Car Audio and Electronics 5 11-24-2005 11:03 PM
do i need special plug wires ? j123crx E21, E30 2 11-20-2005 09:57 PM
