Old 03-11-2007, 04:17 AM   #1
snumfalzumpa
Your Ride: 1996 BMW 328i
How do I remove my tail light lens?
I have a 1996 328i sedan with a cracked tail light lens. I have a new tail light to replace it with, but I don't know how to take out the old one. How do I remove my tail light?
Old 03-11-2007, 08:20 AM   #2
Rate My Car: 106 / 337
They are removed from inside the trunk. You'll see a plastic cover. Remove those, then remove the bulbs by twisting the sockets. Disconnect the wiring harness. Then remove the nuts that hold the lens to the car.
Old 03-11-2007, 09:47 AM   #3
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
should be three nuts, their like 30mm, then they pull straight out.
Old 03-11-2007, 07:01 PM   #4
3050rpm
3050rpm's Avatar
I don't think they're 30mm, maybe more like 8, unless they changed things from '95, which is my model year. In any event, once you remove them, you may need to take a rubber hammer to hit the screw studs with, as the rubber gasket around the lens can form quite a tight seal that could make merely pushing it out a bit of a task. Once out, wash the lip and hit with some wax, check for any rust that may have crept in.
Old 03-11-2007, 07:03 PM   #5
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
30mm seems a bit big... a front axle nut is only 27mm
Old 03-11-2007, 10:15 PM   #6
RSF5
RSF5's Avatar
OKAY OKAY 30mm IS TOO BIG! it was late and I wasn't thinking. Either way there are nuts of a certain size that once removed allow the tail light to slide right out.
Old 03-11-2007, 10:19 PM   #7
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah its either 8, or 10 mm I forget, it's been a while since I did mine.
Old 03-11-2007, 10:47 PM   #8
3050rpm
3050rpm's Avatar
RSF5, don't be hard on yourself, 'cuz as we all know, there are a lotta nuts roamin' around out there...
Old 03-11-2007, 11:02 PM   #9
Wow . . I can't believe there's even a discussion about size of nuts. Just open the trunk for the love of god . . if you can't figure it out on your own . .
(Edit, next morning) . . Sorry, That was mean. Been in a weird fit lately, think I need anger management.
Old 03-12-2007, 12:31 PM   #10
RSF5
RSF5's Avatar
well hey you know what all of your nuts might be 8mm but mine personally are 30. I got me some HUGE nuts
Old 03-12-2007, 06:54 PM   #11
3050rpm
3050rpm's Avatar
Old 03-12-2007, 06:59 PM   #12
Old 03-12-2007, 08:27 PM   #13
RSF5
RSF5's Avatar
^^^ Oh shut up.
Old 03-12-2007, 11:56 PM   #14
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
lol
Right Tail light problem litespan 7 Series (E23, E32, E38, E65, E66) 14 11-29-2006 10:47 PM
WTB '83 320 r & l tail light lens esty Bmw Cars For Sale/Wanted 1 10-26-2006 11:27 AM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
How many forum members does it take to change a lightbulb? bmwcrazy Comedy Collection
6 11-20-2005 08:31 PM
TAil LIght FUN :D xxxbimmer Bimmer Showroom 21 09-13-2005 03:48 AM
